my computer keeps restarting...
Discussion in 'Tech Support' started by BobbyMParr, 18 Sep 2006.
  1. BobbyMParr
    BobbyMParr GameDemon
    18 Jun 2004
    i have been noticing that each night it keeps reseting and its done it 2 me twice 2 day while i was browsing the net.. please help me....
  2. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    Powersupply? On my previous computer the power supply wasent that great, the motherboard power cable was folty. If i nocked my computer it would restart, it would even restart on its own sometimes.
  3. BobbyMParr
    18 Jun 2004
    hmm ill look into a new one mines one that came with the case.... i thought maybe the cpu was messin up or overheating i dont know a whole alot about the workings of pcs i just know them :-D
  4. DougEdey
    5 Jul 2005
    Could be windows update, check that it isn't set to automatically install.
    Also check your system log.
  5. BobbyMParr
    18 Jun 2004
    my auto update is off how do i check the log?
  6. DougEdey
    5 Jul 2005
    Administrator tools -> computer management
  7. mcg1sean
    mcg1sean What's a Dremel?
    5 Apr 2006
    possible overheating? i know that mine does that to me sometimes....check out your temperature in your bios or get a program like motherboard monitor that appear on the taskbar by the clock (assuming that youre using windows)
  8. BobbyMParr
    18 Jun 2004
    i have had mbm for 2 years just havnt had it on its showing about 114 right now... that seams a bit high
    i already ordered a new psu this is the one i ordered http://www.newegg.com/Product/Product.asp?Item=N82E16817148008
    edit #2 i blew my fans out a little bit and its now toping out at 111 so it prolly needs a good cleaning...
    edit # 3 started cs and now im at 134 :-X woooooa!
  9. Neuffy
    Neuffy What's a Dremel?
    22 Jun 2003
    Um...that _better_ not be Celsius.
    134 F = ... 55 C? Doesn't sound so bad then.
    Get a can of compressed air. Get rid of all the fine dust buildup on your cpu fan, as well as on any other fans. Most HSFs will get near-completely blocked in my house within six months.
  10. BobbyMParr
    18 Jun 2004
    well im used to the idle temp i guess that 134 just kinda scared me .. anyway ill clean it out 2 morrow of it keeps acting up otherwise ill wait till my new psu gets here and ill do it then
  11. BobbyMParr
    18 Jun 2004
    BCCode : c2 BCP1 : 00000007 BCP2 : 00000CD4 BCP3 : 00060016
    BCP4 : BC6A0E40 OSVer : 5_1_2600 SP : 2_0 Product : 768_1
    is what i got from error reports this morning i got the full on the system has recovered from a serious error message .....
  12. DougEdey
    5 Jul 2005
    Can you get zips of the minidumps please?
  13. BobbyMParr
    18 Jun 2004
    if someone will tell me how....
  14. BobbyMParr
    18 Jun 2004
    um power supply is here :-D
  15. BobbyMParr
    18 Jun 2004
    the psu is sweet ! and day 1 no restart
