Scratch Build – In Progress My Desk MOD (Update 3-10-2008)
Discussion in 'Project Logs' started by Obou, 2 Feb 2008.
  1. Obou
    Obou What's a Dremel?
    29 Jan 2008
    So this has been bugging me for a while and i got them honey do on hold for a while.
    So I thought I would take care of it today, tell me what you guys think.
    Before Pics
    25 Bucks @ HomeDepot
  2. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    i like the organization, and how nothing is touching the floor.
  3. Cowinacape
    Cowinacape What's a Dremel?
    26 May 2003
    Nice job, a big thumbs up on the desk idea great use of common supplies to make that frame!
  4. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    see, this is why i'm doing a combined desk/PC mod :D (see link in signature)
    People spend ages (and fortunes) in cable management INSIDE a case. Then they junt the case on the cheapest ikea POS table they can find, and have a ton of differently colored wires running in all directions. That just doesn't add up IMHO :p
    This is some good work mate, lots of visual improvement with minimum effort and money spent :thumb:
  5. eXplode
    eXplode sound freak
    1 Dec 2007
    I think ur sub woofer is suposed to be on ground... for better sound...
  6. iwog
    iwog Linux cursed
    14 Jun 2007
    I dont like the way the PC case leans on its shelf. I'd thing about adding something to make it more vertical and look less unstable.
  7. SirShaw
    SirShaw What's a Dremel?
    24 Aug 2003
    cables look a LOT better :)
    Its neat the way you mounted everything underneath there but wont all that weight make your desk sag?
  8. Obou
    29 Jan 2008
    To me it does not effect the way it sounds at all, my wife plays music all the time and I have to kick he off of it because she like the way it sounds better than her computer.
    Yeha, That bug me as well, to tell the truth i forgot to get the part to fix that, i going to add some 90's to the PC self.
    It does sag a little but I think I have a solution for that.
    I will be fixing that later this week.
  9. Obou
    29 Jan 2008
    Needed a Drawer so I made one.
  10. Obou
    29 Jan 2008
    Also added some trim.
