Displays My first 4k monitor
Discussion in 'Hardware' started by dead beat, 28 Jun 2014.
  1. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    I've just taken the plunge into 4k (albeit more towards the budget end) with the ASUS PB287. Yes it is a TN panel, but I bought it for the sole purpose of gaming on, with my 30" IPS Dell still being used for photo editing and other colour sensitive work.
    Anyway, the reason for this thread is just to give my initial impressions of the monitor. It does suffer the usual TN flaws with regard to viewing angles, however this panel seems to be much improved over TN panels of the past. Unless you are sitting very off axis, the issue is not noticeable. Colour reproduction does seem to be very good too. Unless you were doing photo work, the 8 bit colour would not be an issue at all.
    One of the things i'm loving is the sheer amount of desktop real estate. Fortunately I have very good eye site and am enjoying using the monitor without any additional text scaling. Though I expect for a lot of people this would simply not be possible.
    Gaming is where this monitor really excels though. The low lag is great after using the Dell IPS and running the latest titles in 4k makes them so immersive.
    Anyway, if you are looking for a 60hz 4k monitor for gaming and general desktop computing, I would thoroughly recommend this one. TN panels must have come a long way since my last experience with them.
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Sounds good, but you'll need pics to complete the thread! :)
  3. Parge
    16 Jul 2010
    I still can't afford the GPUs needed to run it!
  4. dead beat
    15 Feb 2009
    I'll see if I can get some uploaded later.
    Yes, Even with quad 290s, I still find that I need to have the anti aliasing turned down more in order to get acceptable frame rates. Although the advantage of 4k is that anti aliasing is not really required anyway.
  5. Instagib
    Instagib Minimodder
    12 Mar 2010
    My thoughts exactly. It'll take a few more generations before mid-range gpus can push around all those pixels comfortably. Kudos for being an early adopter though. :rock:
  6. Parge
    16 Jul 2010
    If I had Quad 290s, I'd definitely want one. It would be the only thing that would actually be a challenge for them.
  7. Teelzebub
    27 Nov 2009
    Sounds interesting what's the screen size?
  8. theshadow2001
    3 May 2012
    I have been curious about this for a while now. Hopefully you can help me out. What does a normal desktop on a 4k monitor that's been set 1080p look like? Does it look funky like a clear res mismatch or is it ok or good?
    Apophis54 likes this.
  9. Parge
    16 Jul 2010
    Why would you ever spend the extra cash on a 4k monitor and then do this? :confused:
  10. sandys
    sandys Multimodder
    26 Mar 2006
    Might want to work with the extra res but not want to deal with hardware costs to go native gaming, it's a reasonable request.
    I would imagine on a small 4k screen the scaler should make it look OK, assuming its good, much like how a 1080p screen can make 720p from a console look good.
    the question is whether it has the full 4k scaler meaning it is able to stretch 1080p over the whole screen rather than one side.
  11. sandys
    sandys Multimodder
    26 Mar 2006
    I assume its this screen Here
  12. Shirty
    18 Apr 1982
    Surely with 1:4 scaling on the pixels, 1080p would look as good on this screen as any other of this size?
  13. Parge
    16 Jul 2010
    He asked what a normal desktop would look like at 1080p......
  14. theshadow2001
    3 May 2012
    @parge
    Because you could game at 4k and also not need a pair of binoculars to use the desktop.
    Windows has scaling but it's not perfect. Some applications just ignore it.
    Also it's pure curiosity would 1:4 scaling work well on it own or does there need to be rendering software doing things to make things look ok (ala windows native scaling when it works)
    As an after though, There's also gaming where there are no sli or crossfire profiles. I remember one of the Assassin's creed titles just not doing anything with my sli config. In fact it may have worked better with sli disabled. I'd like to see a bad port try to run on a 4k screen with no multi gpu configs.
  15. dead beat
    15 Feb 2009
    If you set scaling to 150% the resulting desktop is identical in picture to if you were using a 1080p screen. Everything remains pin sharp. As has been mentioned, there may be some apps that don't scale too well, but all the Microsoft stuff seems to be fine.
    I'm probably not going to bother with scaling. At 28" text is just large enough that I can get away with it. Infact i'm really loving the extra space.
  16. dead beat
    15 Feb 2009
    Yes that's the one.
  17. Jim
    Jim Ineptimodder
    2 Sep 2007
    Pretty much the same story here with the Samsung U28D590D, although I'm gaming with a GTX 760.
    I haven't tried anything too recent yet, but it will be interesting to see what happens when I do. I imagine I'll have to play around with the settings a fair bit.
  18. bsp
    bsp Minimodder
    25 Dec 2010
    :hehe: :lol: :hehe:
    Now back to the review:
    Thanks for your review. I don't think I can manage anything outside of 24" given my distance from the screen. Real estate is nice but I assume that you are sitting far enough back that you can see the whole thing?
  19. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    this would probably blow me away you're already used to large with that dell 30".
    the ultra wide monitors look interesting as well.
    edit: using on sreen keybord,lol cause i disassembled mine and washed it..it got just too gross takes ages to dry.
  20. Mark_Skeldon
    Mark_Skeldon What's a Dremel?
    5 Feb 2012
    I've got 20x 290s that I'm retiring from a mining farm. I'm just stuck trying to find a Z97 board that will fully support 3-way crossfire and not be bandwidth hobbled along the way. Not as easy as I was expecting! :wallbash:
