Build Advice My first custom pc build
Discussion in 'Hardware' started by rclacko, 5 Jul 2009.
  1. Guest-16
    Guest-16 Guest
    You cannot plug DDR3 into a DDR2 motherboard! :)
    If you dont think a 400W will be enough - try the OCZ ModXStream Pro 500W - £58 usually.
    4GB of 1066 memory should set you back less than £45 as well.
  2. rclacko
    rclacko What's a Dremel?
    5 Jul 2009
    But it says on the technical spec that it accepts ddr3 1600 ram :S
    Jambo, i think i might just do that, i've had a play around with one of the beta versions a few months back and it seemed pretty stable.
    edit: actually it says ddr3-1600 under the memory speed, not memory type. why would it say ddr3-1600 in the memory speed but says it only accepts ddr2 ram?
  3. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    Must be a mistake when listing the board.
