My firstMOD! UPDATE ! 7/4/05
Discussion in 'Project Logs' started by venomz, 22 May 2005.
  1. venomz
    venomz What's a Dremel?
    16 May 2005
    bad news guys i have to redo that side panel :( iforgotto take theblue tape off the plexi .you no the blue tape that stops scratch's.it was all comeingg off so i just took it alll off and im ganna redo it:( ccrys 2weeksworth of work down the drain.
  2. kill_me_quick
    kill_me_quick Big and Blue
    7 Jan 2004
    Looking nice mate.
    been following this log but shame someone told you to resize your pics, now you cant see anything in the 1st few. I personally think 640x480 is a good resolution, preview pic underneeth:
  3. venomz
    16 May 2005
    oh so i should put the pics back to the way theyu were cuz i have all theragular size'ssaved.
  4. kill_me_quick
    7 Jan 2004
    Well I prefer them as 640x480 ish because you can actually see what is going on in them, for example the picture of you bed. that looked good but you can hardly see what it is now. Its up to you what you do, or you can put a link to a full size image ill do a quick example:
    Code:
    [URL-the full size picture.jpg ect][IMG]the thumbnailed image[/IMG][/URL]
    (PS change the - for an = in the URL bit)
  5. venomz
    16 May 2005
    so thats the code to do that???? i would do that for sure. how does that codeing shrink the picture and when you click on it it enlarg's?
  6. venomz
    16 May 2005
    any waise im ganna edge this picture into my new panel immaken . what im going to do is havea top and bottom window. imganna have 2" sides like i did last time. and im ganna edge the bottom window. this is thepicim g anna use im only ganna use the ghost picture.. [​IMG]
    thats what im going to edge into the window. well im not going to edge the window . some one els is.'
    edit i desided not to use that picture.
  7. venomz
    16 May 2005
    thats what i might use . but ill think about it.
  8. kill_me_quick
    7 Jan 2004
    No that code is for two seperate pictures, so you have a small thumbnail, like you have now and then you put the link for the larger picture in the bit that says "-the full size picture.jpg ect" so you would have something like "=http://i6.photobucket.com/albums/y236/venomz/NKodeNKodeArtwork11024x768.jpg"
    Do you get what i mean now?
    btw i like the image, but it looks like a lot of work to engrave that.
  9. venomz
    16 May 2005
    well guysi just gotmy 2" tubes each arein 3' each. cost me 17$ and i bought somearclic cament. soi can make watertightseal. i started to get my res that i made befor but im ganna put 2 2" tubes in it besides using thewhole thing. looks alot better. :) ill post pics soon :D . ill take a pic of the res after it drys cuzi just wet sanded the inside im ganna primer it next.
  10. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    thats going to be one bad @$$ window!
  11. venomz
    16 May 2005
    yeai no it is! lol. bad news is i have to redisgnit.im acully glad it did mess up. cuz i havebig planesforthenext one .!like im going to etchthat picture into the plexi . well some one els is.:) im almost done my other panel just finishing up somesanding. last part im going to do is wet sand! and then iput primer on then chrome.
  12. venomz
    16 May 2005
    im buyingn this rad tonight should get it ina week or so. http://www.performance-pcs.com/cata...=2318&osCsid=d5da6befa4c7a75c9751eefa04b94b9e
    other words here are some pics. i have2 of these 2" tubes i got from tap plastic. heres the 2"tubescutdown toabout 11" im cutting it down to 10" so. [​IMG]
    here are thebrassfittings ill be useing for my pc. [​IMG]
    heres a pic of my res and side panel im worken on. hehe the results is a mega smoth panel that im going tobe putting chrome on all over it !.
    my rad is going on that side panel.
    heres the thing im putting my res in. [​IMG] im putting 2 10" tubeing in it. it will look 10 times betterwhen i chromethe inside and put diamond plateing onthe side and top . thats how im going to incase my insides with diamond plateing.
    this is also the pump ill be useing for my res. im thinking about stealthing it i dont no. i might just leave it alone. http://www.dangerdenstore.com/product.php?productid=175&cat=23&page=1
    i got all my fittingsat home depot.
  13. Mondak
    Mondak What's a Dremel?
    27 Dec 2003
    Pretty neato. Looks like someone likes diamondplate that is for sure.
    You always seem to mod in bare feet. Watch out for metal splinters!
  14. venomz
    16 May 2005
    hehe im justlazy with shoes.
  15. venomz
    16 May 2005
    some more pics!
    heres a pic of my side panel on my pc all primered up ready for chromeing.
    heres a pic of the diamond plateing inside my pc all rivited in. man you cant even see the rivits :) looks soo clean. dont it!
    heres a pic of the NEW side panel . its a bummer that i had to make anew front side panel. this time!!! i took off the blue tape!!! that WONT happen agen hehe.
    i acully like this one better cuz im maken a curve to it.
    what im worken on next on my pc is the frame for my cd drive bay area. because im going to be incaseing that with diamond plateing also
  16. omicron
    omicron Baud.
    8 May 2004
    Sounds familiar...;).
    Looking good so far. Love the checkerplate. A little bit of advice though dude, TRY to condense your posts a bit. Instead of posting three times with just one sentence, edit your previous post. Also, please use a spellchecker - some of your posts are indecipherable!
    Good luck, I'll keep an eye on this..
  17. venomz
    16 May 2005
    does this forum have spell check?
  18. ex421
    ex421 What's a Dremel?
    20 Jun 2005
    waht is splell cehck??
  19. Stuntman
    Stuntman Minimodder
    22 Oct 2004
    *gasp!* You stole my motherboard!!!
    :p Nice mod!
  20. frodo
    frodo What's a Dremel?
    1 Nov 2003
    looks pretty clean
    keep it up!
