CPU MY H60 is making churning noise.
Discussion in 'Hardware' started by mat0tam, 1 Feb 2012.
  1. mat0tam
    mat0tam Mr I Dont Know What I Want
    1 Sep 2011
    Just wondered if any else seems to have an issues with there H60 or similair device.
    Mine seems to making far more noise than it used to, likes its churning air'ated water about? Tried making the cpu the lowest part of the loop but it still occurs,
    Any advise?
  2. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    how old is it ?? there been a batch or something with air or damaged pumps.
    If its in warranty RMA it
    Corsair Forum H60 noise
  3. Jipa
    5 Feb 2004
    You shouldn't need to do anything special with the closed loop sets, and if it suddenly, after some use, develops such noise it's time to get the unit RMA'd.
  4. Cei
    Cei pew pew pew
    22 Mar 2008
    RMA it. I had a H80 that did the same thing, Corsair replaced it.
  5. mat0tam
    1 Sep 2011
    Its only like 3/4 months old. It may be because my system is pretty silent. Its just annoying.
    Can hear it over 3 nexus silent fans at full load.
    @CEI - Who did you contact for an RMA? supplier or corsair?
  6. Cei
    Cei pew pew pew
    22 Mar 2008
    Corsair, they handle all RMAs direct rather than through retailer. Should have been a slip in the box if you still have it.
  7. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    at 3 or 4 months go for supplier they may pass it on but should deal with it
    (Saying that depends were you bought it from)
  8. mat0tam
    1 Sep 2011
    Il dig that out tonight. Dont really want to part with a cpu cooler while its dealth with but its annoying that ive spent so much time on fans and making the pc quiet to have a pump churn away in the background :(
  9. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    have you clocked your i5 2500k ???
  10. mat0tam
    1 Sep 2011
    Previously ive clocked it to 3.7 in bios but its been at stock for a month or 2. No need for clocking right now
  11. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    only asked as if its not just slap the reference cooler on they normally don't take that long to rma
  12. mat0tam
    1 Sep 2011
    Ah ok, Can make my case like a wind tunnel if needed anyway haha. RMA entered, less concenrned about the noise than the fact im running with a faulty cooler (and that I paid retail for it :jawdrop:)
  13. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    ive heard alot of issues with corsair units
    but ONLY the h60 / h80
    never with the h50 / h70 that came beofre them...
    but from what i heard there was a bad batch but no1 seems to know exactly what makes the batch bad, why it happens...or how to stop it ( corsair are remaining tight lipped )
  14. Atomic
    Atomic Gerwaff
    6 May 2002
    I had three faulty H60's in a row. Their Quality Assurance is awful, I'd not buy one again!
  15. lilgoth89
    12 Mar 2011
    if the store has 100 of the bad batch...most of them will have this problem.
    should imagine corsair will do a re-call on the affected batch
  16. Atomic
    Atomic Gerwaff
    6 May 2002
    People all over the world have had problems, I'd say it's an entire production run that's faulty rather than a bad batch.
  17. Jipa
    5 Feb 2004
    They went from Asetek to CoolIt, didn't they? Sigh.
    EDIT: I'd almost forgot, but also my H100 was noisy. Wouldn't stop making the damn noise no matter how I twisted and turned it.
  18. lilgoth89
    12 Mar 2011
    yup the h50 and 70 were made by asetek...the h60 and 80 are made by coolit
    worst move they made
  19. towelie
    towelie How do I Internet!!
    1 Sep 2011
  20. mat0tam
    1 Sep 2011
    Just waiting for a reply from them. Considering air cooling or a h70 upgrade
