Scratch Build – In Progress My scratch build. 6/19 Started to paint.
Discussion in 'Project Logs' started by Halchart, 23 May 2012.
  1. Halchart
    Halchart What's a Dremel?
    26 Jul 2011
    I posted a while ago about starting my scratch build and now I finally have some free time to start it.
    here's the sketch-up design.
    This is HTS-2000 an aluminum brazing rod. This is what I'm going to use to put the frame together.
    Makes a good strong joint.
    This is the frame with the motherboard tray in place.
    With the top and side panels in place.
    I used 1/8" aluminum plate for panels and a few different sized angle aluminum for the frame. I'm just waiting for the screws i ordered to come arrive and i still have to place an order with mnpctech.com
  2. Halchart
    26 Jul 2011
    Sorry about the late update I started right before I took the wife and kids out on vacation. But I have gotten a little more done.
    got my socket caps and all my panels cut and mounted.
    and cut the hole for the optical drive.
    I get paid tomorrow so I will be ordering fan grills and a few other things. Thanks for looking.
  3. Gluthtew
    Gluthtew What's a Dremel?
    21 May 2012
    I think, that you are mistaken. I can defend the position. Write to me in PM, we will talk.
  4. Halchart
    26 Jul 2011
    I don't know what I am mistaken about. But I cant send any PM's yet.
    I also have a little update I just finished a circuit for lighting my case. It will alternate between two different strings of LEDs they fade in and out. Once i get a moment to get a vid I will post it. I also ordered my fans and a couple of MNPCTechs Nautilus Fan Grills.
  5. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Looks good off to a great start!!:rock::dremel: what size are those Allen caps looking at using them on my mod in m3 size.
  6. Halchart
    26 Jul 2011
    On the front, back and top I used 6/32 and the sides i used a 4/40 flat socket cap.
    http://www.fastener-express.com/ is where I got them from.
  7. Halchart
    26 Jul 2011
    Got home from work today and had a couple packages waiting for me.
    Xigmatech fans.
    A couple MNPCTech Nautilus fan grills. These thing look way better in person. :D
    So a little cutting and.
    I love the way these grills look. Also I had done the back a few days ago.
    The PSU in there is an old one just making sure it fits. But I think I'm gonna need a grill of some sort for the rear fan.
  8. bluc
    4 Apr 2012
    Looks good I think the grills are a good choice:thumb:
  9. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Cool project and another Minnesotan! welcome to bit-tech Halchart! :rock:
    lookin forward to seeing your build when it's finished :thumb:
  10. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    This :thumb: ;)
    Looks good so far! Keep it up :dremel:
  11. Halchart
    26 Jul 2011
    @bluc thanks for the comments.
    @mnpctech thanks but I realized when I placed my order I forgot to add some modders mesh so expect another order soon :wallbash:
    @Mosquito thanks it's cool to see more Minnesotans in here.
    Right now It's on hold till the heat comes down a bit. It's way to hot in my garage right now to work but the temps are supposed to drop next week.
  12. Mosquito
    24 Mar 2011
    Should have been working on it in February, when the temperatures were in the 70s :p... crappy winter....
  13. mnpctech
    21 Apr 2003
    PM me before ordering! :thumb:
  14. Halchart
    26 Jul 2011
    lol... Yeah it was a pretty weak winter. Too bad I didn't have the funds then.
    Little update.
    This is the fading circuit I'm using for some accent lighting in my case. I'll probably change to an alternating white and blue LEDs. Right now I plan to place some under the mobo tray and the mobo itself.
  15. Halchart
    26 Jul 2011
    Started painting a little.
    MNPCTech grooved case feet. (taken from an old mod and painted)
    And the Overkill grills. Both were painted with Dupli-color metalcast paint so they look alot like they've been anodized. I got a new PSU on order and already got my sleeve waiting for it to arrive.
  16. bluc
    4 Apr 2012
    I like the paint and your right it looks like its anodized!:thumb:
  17. mnpctech
    21 Apr 2003
  18. bluc
    4 Apr 2012
    How your mod going managed to make any progress?
  19. Halchart
    26 Jul 2011
    @ mnpctech Thanks for the heads up. I'll have to buy some this weekend.
    @bluc going good working on sleeving a power supply right now. I get paid this week so I will be buying paint. Hopefully will have some new pics this weekend.
  20. Mosquito
    24 Mar 2011
    Agreed with Bill, the plastikote is good stuff. I use it on cast iron (hand plane restorations) and it works great.
    This paint is looking good, keep up the good work :)
