I need to mount this under a table. As you can see the mounting holes are opposite of each other. I believe this was designed to be mounted from one side or the other, not at the same time. Any suggestions would be very helpfull. Thank you Sorry about the size of the pic.
make a template out of construction paper or some paper on the thick side or even a cereal box, grab a thumb tack, tack the template up where u want it mounted and drill the holes and put the skrews in.
Take a thin sheet of wood... and -->bolt<-- it to the sheet of wood, using the existing holes, then mount the wood peice to the table. Or make some sheet metal beackets...
