Right i brought this below... What... I need is the top panel made in clear acrylic with an engraved picture on top and bevelled edge around and screw holes the to be counter sunk. Dimension:200*80*225 mm (W*H*D) Let me know if you can do the job inc cost?
Hi, I want to buy it as well. Can tell me please - does it come with 120W PSU but only 60W brick? Does it mean that when I install 65W CPU I may not even power it up? Can you fit in 3.5" regular hdd and stock intel cooler?
It might power up but you may run into problems according to this. Maybe buy the case only and a separate PSU? Or upgrade to 120w brick?
£30 for 120W picoPSU and case isn't much, thought I would buy it. but this 60W brick is putting me off. Getting proper brick would be around £20.
