I want a dremel that would be able to do anything from small holes in plexiglass to cutting holes for windows in (thin) of cases. Also, suggestions on some specific bits like which blade brands are good. Thanks
Dremel 300. Probably. Does all the basics, just buy attachments as you need. Can't say much more than that really.
Make sure you get the reinforced cutoff discs. The standard ones that come with it shatter quite easily. And the reinforced ones last a lot longer too.
Just make sure sure you get a REAL Dremel with a Dremel warranty. Don't be talked into a cheap imitation. Real Dremels survive well, the brushes on must can be changed and if anything else quits they honor their warranties. john
