Need help choosing the perfect LCD monitor
Discussion in 'Tech Support' started by Steve-0, 7 Mar 2008.
  1. Steve-0
    Steve-0 What's a Dremel?
    4 Feb 2006
    has to be a 24inch and my budget is 550$
    has to have HDMI, DVI, HDCP, and can view/play etc in 1080p (if possible)
    im using an old 21inch crt monitor, which has reached its years of use
    over 10 years old.
    I was thinking about samsungs new 24inch with 10,000:1 ratio
    im a gamer, so that should be put into spec
    thanks!
  2. Squadexodus
    Squadexodus I got my cookie. What about you?
    5 Jan 2008
  3. Steve-0
    4 Feb 2006
    hmm...doesn't say the price for US
    i'll look for it on net though, looks like an awesome monitor definitely
  4. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    It's easy enough to convert £ --> US$. The exchange rate is as near £1.00 = US$2.00, as makes no difference.
    So in theory, you'd just double the £ figure, to get the equivalent US$ price.
    But of course it doesn't always work like that, because you folks stateside, can invariable get computer gear quite a bit cheaper than here in the UK :wallbash:
    The £400 for that monitor, would normally translate to $800... but I'm betting the monitor doesn't cost anything like that over there?
    Newegg don't appear to stock Hyundai monitors... but they do have plenty of other 24" screens which are well within your US$500 budget
    There are far lower priced ones (<$400), but of course you're wanting HDMI and 1080p... which narrows your choices considerably.
    But at $499.99... this Samsung 2493HM is right on the money, and Samsung screens are renowned for their quality looks :hip:
    Dunno what resolutions it does though? But most of the better/more expensive 24" screens do 1920 x 1080 (= full HD/1080p) :idea:
  5. Steve-0
    4 Feb 2006
    yep thats the same samsung monitor i had my eyes on
    but someone else on here said the lcd film technology is old or something
    not as bright?..i don't know what the difference is between TFT and all the others...
    PS: yea you guys get ripped off badly over there :(
    i'd go berzerk if i had to pay that much...
  6. Steve-0
    4 Feb 2006
    Just read more reviews on that Samsung LCD. not very good for 1080p or 1:1 scaling
    so i did all 24inch screens by best rating, and came up with this
    http://www.newegg.com/Product/Product.aspx?Item=N82E16824255001
    Westinghouse model, looks good to me, how bout yall? :)
    EDIT!
    I need an HDMI cable
    found this one, http://www.newegg.com/Product/Product.aspx?Item=N82E16812189054
    the westinghouse doesnt have DVI, but it has HDMI
    My radeon 3870x2 came with an HDMI adaptor
    but i dont know what type of cable to get, has to be from 7-10feet long
  7. Hazardous
    21 Jan 2004
    I know a couple of guys in the USA on other forums who are using Westinghouse screens, and they're all happy with 'em :cooldude:
    And yeah... any HDMI - HDMI cable of suitable length is what you need ;)
  8. Steve-0
    4 Feb 2006
    hmm. so having no DVI isn't bad at all right?
    as long as i hook the DVI-HDMI adapter to the back of my vid card, and hook it to the screen im alright?
  9. Squadexodus
    5 Jan 2008
  10. Hazardous
    21 Jan 2004
    Nope/yup :D
    However... it's been my experience, that dongles/adapters have a habit of 'drooping', due to the weight of the cable connected to them.
    It would be better therefore, to use a HDMI - DVI cable, so you have a direct connection from the graphics card to the monitor :idea:
    And IMO, it would be worth investing in decent quality cable - i.e. this AMC Premium Gold Series, to ensure the highest possible picture quality?
    It's only $18 after all, and why skimp on the cable - by opting for one which is <$10, when you've invested many hundreds of $ on the graphics card and monitor :idea:
  11. Steve-0
    4 Feb 2006
    ok im gonna get that hannis 28inch, on wednesday.
  12. Hazardous
    21 Jan 2004
  13. Steve-0
    4 Feb 2006
    W T F
  14. Steve-0
    4 Feb 2006
    guess if i wait again they might drop it..
  15. Steve-0
    4 Feb 2006
    Im gonna get the new Dell 2408WFP if i can find it anywhere but the dell site lol
    total rip-off heh
    anyone know anywhere else to purchase it?
  16. customh
    customh conflagration.
    22 Oct 2005
    I would recommend the 2408wfp, seeing as I am watching the Colbert report on it at my friend's house right now, and am selling my 20.1" Samsung 205bw to buy my own. Why has no one else recommended that?
  17. computerman5
    computerman5 What's a Dremel?
    30 Aug 2007
  18. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    I just bought a Dell 2408WFP. Its niiiiice. :D
  19. Steve-0
    4 Feb 2006
    how much does it cost in quids?
    and to use 1080p HD, do you have to use an HDMI - DVI adaptor
    or can you use the full HDMI cable?
  20. oasked
    24 Aug 2005
    It has an HDMI connector, so no fiddling with cable necessary. It also has a displayport connector, component in, VGA in, 2xdvi in, an SD card reader etc. :)
