Modding Need help fast!
Discussion in 'Modding' started by Bones, 16 Dec 2004.
  1. Bones
    Bones What's a Dremel?
    14 Nov 2003
    I am sleeving my power supply and i had a diagram i made of the atx cable and i was taking out the pins and realised it was done wrong :duh: is there any diagrams that are availible online or something to show me where they go or are they all different for each power supply?? Thanks!
  2. user0001
    user0001 What's a Dremel?
    8 Sep 2004
    The color of the wires might be, but once you find out which color is what voltage, know that all that color can be interchanged. Google for ATX pin layout.
  3. BobbyMParr
    BobbyMParr GameDemon
    18 Jun 2004
    is a p4 hookup with 20 or is it 1 of those 24 pin thingys if its a 20 ill send ya a pic of mine
  4. Bones
    14 Nov 2003
    thanks its one of the p4 with the 20 if you could send me that that would be great thanks!!!!
  5. BobbyMParr
    18 Jun 2004
    this image was made as if i was looking down at the top of the connector "the side you stick the wire in"
  6. Bones
    14 Nov 2003
    Thanks!
