PSU Need help finding a good quality thin ITX PSU
Discussion in 'Hardware' started by Fingers66, 2 Jun 2019.
  1. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Hi all,
    I have a Gigabyte B85TN thin ITX board for a project and am looking for some suggestions for a good quality 19v PSU (laptop type). It needs to have connector dimensions of 7.4 x 5.1mm and will be running 24/7.
    It will be driving a 35w CPU, a couple of SO-DIMM RAM sticks, a small mSATA drive, a single 92mm fan and four 3.5" hard drives - I am assuming that 150w would be enough?
    I have been searching but I am getting lost in the noise that is PSU listings and need a recommendation for a good quality unit that will not blow up in my face.
    Can anyone suggest something suitable?
  2. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    How about HP P/N: 681059-001? It's a 180w PSU from an all in one so it should give you some headroom and I think it has the right barrel type. I used a 120w version from a smaller HP AIO for my thin ITX PC back when ebay had those £16 boards. Here's a used but genuine one for £30.
  3. Fingers66
    30 Apr 2010
    Thanks for that but I was hoping to get a new one from a trusted source - I already have a Dell 130w brick that fits but it is old and I need this project rig to be running 24/7 so a new one I think is better.
    There are loads available on the net but I don't know who to trust to source one for a reasonable price, I've heard many horror stories about cheap PSU's.
  4. lancer778544
    5 Jan 2011
    I can get new and genuine HP PSUs via my work, I'l do some digging and get some prices for you if you'd like?
  5. Fingers66
    30 Apr 2010
    Sounds good, let me know please.
  6. lancer778544
    5 Jan 2011
    So @Fingers66 , I can get you HP P/N: 849653-004 which is another 180w HP unit (that I think is 89% efficient?) for just shy of £60 delivered to you with a bit of lead time unfortunately, about 10-14 days. I've also found a 120w unit, P/N: 906329-001 but that's nearer £70 for some reason but is available within a few days. If you need even more power, a 230w HP unit, P/N: 693706-001 is £135 but also available in a few days.
    I've also had a look for Dell PSUs:
    130w - VJCH5 - £75 - 7-10 days
    150w - J408P - £85 - 10-14 days
    180w - DW5G3 - £95 - 3-5 days
    Sorry mate, probably much more expensive than you were expecting but these are 100% genuine PSUs. If you find any other PSU P/Ns during your research feel free to ping them my way and i'll get you costs on them :)
  7. Fingers66
    30 Apr 2010
    Thanks for looking, I'll keep looking myself and hope to find a reputable seller.
  8. lancer778544
    5 Jan 2011
    No probs :)
