Modding Need help picking a LCD screen for my Lian Li case
Discussion in 'Modding' started by Stussy, 13 Apr 2003.
  1. Stussy
    Stussy What's a Dremel?
    13 Apr 2003
    alright i have the Lian Li PC-60 I do not have a floppy drive and looking to put a LCD screen in where they (3) 3 1/2. Saw several sites this one looks to be the best. http://www.matrixorbital.com/ I need some one to let me know what LCD screen I should get and will look best in my comp. thanks a lot
  2. Stussy
    13 Apr 2003
    *bump* (need help) thx ;)
  3. Cheese
    Cheese Doc
    6 Oct 2001
  4. Sid
    Sid Banned
    13 Mar 2002
    matrix orbital probably make the best displays i think. if you can afford it go for a nice big vfd like the Matrix Orbital VFD2041 or the VK204-25. as for mounting, erm, sum1 with a lian-li stuck their vfd/lcd in the 3 3.5" bays before, I'm trying to think who it was [searching for post]
  5. m0nk3y
    m0nk3y What's a Dremel?
    25 Oct 2002
    Phire has a lcd in his (3) 3 1/2" bays
  6. Sid
    Sid Banned
    13 Mar 2002
    i found that when searching but isn't that a tft?
  7. cderalow
    cderalow bondage master!
    23 Jan 2002
    yeah thats a tft from parts express if i remember right.... 5" using composite video input
  8. Stussy
    13 Apr 2003
    Cheese: read through your LCD faq (helped me out alot) on all the little question i had. Seeing the LCD and the VFD, I like the VFD a lot more.
    Sid: Checked out matrix orbital and looked at the 2 models u gave me. I am defintly going VFD, now what is the differnece between the VFD2041 and the VK204-25? The VFD2041 has keyboard interface and 1 general pupose output, and the VK204-25 has 25 keys interface and has 6 general purpose outputs. Now what one should i go with ? and what is the link that has pics of Phire's case that has a screen in it
    thanks a bunch both of ya
    ¤§†Ü§§µ¤
  9. Cheese
    Cheese Doc
    6 Oct 2001
    You answered your own q about the diff between the VFD2041 and the VK204-25 - if you think you're going to use GPO's then go with the -25, if not don't (I think the keypad interface is largely redundant unless you're using the lcd on a keyboardless system).
    Rob.
  10. Stussy
    13 Apr 2003
    What is GPO's ?
  11. Cheese
    Cheese Doc
    6 Oct 2001
    Read the FAQ ;)
    Rob.
  12. Stussy
    13 Apr 2003
    alright, got some pics and need some help. The 1st pic is a pic of the back of the VFD2401 and the 2nd one is the VK204-25.
    http://www.matrixorbital.com/manuals/vfd2041/image008.jpg
    http://www.matrixorbital.com/manuals/vk20425/backslbl.jpg
    they both have the power connecter and the com ports, then the VK204-25 has the input for the Keypad and 6 GPO (general purpose output) ;) found out what that ment. Now back at the VFD2401 it has the only 1 GPO. What will more GPO allow me to do? Any help would be great thanks. :D
    changed the [​IMG]
  13. Sid
    Sid Banned
    13 Mar 2002
    I'm not entirely sure, but I believe that the top one will allow you to use a basic keypad that you could find on the MO website. But the bottom one will allow for much more sophisticated things...
  14. MbayAQ
    MbayAQ What's a Dremel?
    10 Feb 2003
    cheapest?
    What would be the cheapest lcd display (probably 20x2, correct me if im wrong) that one could find? Thanks.
  15. mookie
    mookie very nawty<br><img src="http://mookie.org/i/avatar
    30 Jun 2002
  16. Stussy
    13 Apr 2003
    Opps sry didnt know aobut the pics, wont happen again :rolleyes:
    ¤§†Ü§§µ¤
