Portable Need help with a charger
Discussion in 'Hardware' started by IamJudd, 10 Sep 2020.
  1. IamJudd
    IamJudd Multimodder
    30 Oct 2011
    I'm trying to find a third party charger to test an ASUS X705M for a friend.
    Amazon has come up short with exact specifications and eBay seems like I'll be getting it from Eastern Europe.
    I need to find something from a reliable source with the following specifications -
    19V
    1.75A
    33W
    5.5mm connector
    Any advice will be very much appreciated as the warranty runs out on the unit in just over a week and she doesn't want the unit wiped if returned without backing up first!
    Thanks so much in advance!
  2. David
    7 Apr 2009
    I'll have a look tonight - I have a bunch of laptop bricks - most of them are 19v but I'm not sure on the barrel size.
  3. IamJudd
    IamJudd Multimodder
    30 Oct 2011
    Thanks matey
  4. IamJudd
    IamJudd Multimodder
    30 Oct 2011
    I've bought one and will check if it works tomorrow!
    Works fine and dandy!
