Electronics NEED HELP WITH LCD WIRING plz!!!!!!! quick!!!!!!
Discussion in 'Modding' started by Bboy_Jon, 19 Dec 2004.
  1. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    OK this is my LCD
    Seiko L1642B1L
    heres its data sheet
    http://www.eio.com/l1682.pdf
    ok so I dont have any pots, so do i NEED resistors?
    ok so is this what i do?
    Pin 1 is GND
    Pin 2 is +5V
    Pin 3 is contrast right?
    so i take a molex connector, then i Wire pin 1 to a black wire, then pin 2 to the red wire, and pin 3 to the other black wire. Is that correct? or do i wire pin 3 directly to pin 1?
    So grounding pin 3 will give max contrast, what does it look like?
    ok and then pins 15 and 16 are the LED Backlight, how do i wire those up? which pins do i connect them to?
    ALSO, Do i need to have a Printer parallel cable, one with the parallel port that plugs into the computer, and has the centronics connector on the other end, or can i just use any parallel cable? Because i dont have any with a centronics end (thats not in use) all i have are db 25 pin male, extension (both ends are males, with the pins sticking out) so can i just use that? Or do i have to use one with a centronics conector on the end?
    ok quick summary
    pin1 goes to black wire on molex
    2 goes to red
    3 goes to other black wire?
    then where do pins 15 and 16 connect to?
    then do i NEED a cable with the centronics connector? or can i use a db25 male pin to db25 male pin extension (both ends are the sides u plug into computer parallel ports)
    please help!!!!! pzlplzplzplpzlpzlplzz
  2. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    OMG!!! I'd better reply quickly!!!!!11 :p
    Pin3 can be connected straight to Pin1 if you want maximum contrast, which is usually fine for these types of LCD's. If the link in my sig is still working, the LCD on my controller has Pin3 connected straight to ground for max contrast.
    You will need a resistor for the backlight. Use a 10 ohm 0.5W resistor. Pin 16 to ground/pin 1. Pin 15 -> resistor -> +5V or Pin 2.
    You can use any lead with DB25 connector, provided it has enough pins connected. The fatter the cable, the more likely this is... :)
  3. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    well wouldnt a db25 conector have 25 pins? lol
    ok well, do i have to connect pin 3 to pin 1 or can i just connect it to a ground/black wire on a molex?
    k so i NEED the resistor? dammit i dont have any resistors here at all hehe, but do i NEED them? can i just wire it directly to pin 2?
  4. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
    Yes, you need the resistor for the LED backlight (10 Ohm was correct for that LCD, it has forward voltage of 4.1V and 100mA rating). If you dont, you burn out the backlight.
    Second, some people have had no problems with tying the contrast voltage to ground. I think this is a mistake. Each and every LCD has variance for its contrast. Using a 5k potentiometer is the best way to adjust the contrast. If you dont use the pot, then the contrast will be set and possibly make the LCD only viewable at a certain funky angle. These parts are not expensive, you can locate the resistor and pot for less than a buck. Thats much easier than trying your hardest to bypass these components.
  5. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    ok, hold on arent i suppose to use a 10k or 100ohm pot?
    the 10k is for backlight isnt it? and the 100ohm is for contrast? Ok so should i use both a pot and the 10 ohm for the back light? does digikey sell 10 ohm resistors?
    Can someone give me a link to all the parts id need? I guess ill just order them, 10 bucks shouldnt be too hard to make up
  6. Explicit
    Explicit What's a Dremel?
    23 Dec 2002
    I need help with annoying people who don't know how to turn caps-lock off, plz, quick.
  7. Hazer
    14 Apr 2003
    10 Ohm resistor for BACKLIGHT.
    10k pot for CONTRAST.
    Ive already looked at a datasheet better than the one you linked. Those are the recommended values.
  8. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    Uhh.....what?
    [/spam]
    :eyebrow:
  9. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    so i dont need to get a 100 ohm pot? i thought that the 10k was for the backlight
  10. Hazer
    14 Apr 2003
    The datasheet recommends a 1k to 10k pot for the contrast.
    If you use anything more than 10 Ohms for the backlight, there will not be enough current to light up the LEDs. They have a forward voltage of 4.1V and require 100mA for proper lighting:
    5V - 4.1V for LEDs = 0.9V for the current limiting resistor.
    0.9V @ 0.1A means: 0.9V/0.1A= 9 Ohms, or the closest value being 10 Ohms. Anything higher will dim the backlight too much, anything lower will burn them out.
    0.9V * 0.1A = 0.09 Watts. A 1/4watt resistor will do fine.
  11. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    lol i didnt understand any of that haha
    Does digikey have the right 10 ohm resistor? Can i get a link?
    Some guy is gonna send me a 100ohm pot (hopefully) and thats for the backlight or the contrast?
    and im probly going to pick up a 10k at radioshack
  12. EdHunTer
    EdHunTer What's a Dremel?
    8 Apr 2004
    the 100 ohm pot should be used with the backlight it would hardly do any difference with the contrast.
  13. SteveyG
    23 Nov 2002
    Not true. It would still work for contrast adjustment, as you're still making a potential divider with the full 5V swing, you'd just be wasting 52/100 = 250mW which the pot may not be able to handle.
  14. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    ok so i need
    100ohm pot for backlight?
    10kohm pot for contrast
    and a 10ohm resistor for the back light? that would be the rlimit thing?
  15. EdHunTer
    8 Apr 2004
    ok i tried using a 100 ohm pot with contrast and it changed very little so i won't argue with that the 100 ohm pot goes to backlight the 10 kohm pot goes to the contrast. and forget the 10 ohm resistor FORGET... it's only needed if you'll be using the backlight pot on a regular basis and other ppl have access to it (you should be able to remember not to crank it up to max :D )
  16. SteveyG
    23 Nov 2002
    It'd argue that it's important to keep the 10 ohm resistor in series with the output from the 100 ohm variable resistor. If you don't use it you'll not know if you're damaging the backlight...
    At least if you keep it, you'll know you can vary the backlight over the whole range of the pot. I don't know about you, but I'd rather spend 0.3p on a 10 ohm resistor instead of needing a new backlight...
    Bboy_Jon, your list is correct.
  17. Hazer
    14 Apr 2003
    I have no idea where anyone suggested a 100 Ohm pot for anything.
    Its very simple:
    5V--->10 Ohm resistor---->pin 15
    Ground--->pin 16
    Ground---->pin1 and outer leg of 10k pot
    5V---->pin2 and other outer leg of 10k pot
    middle leg (wiper) of 10k pot---->pin3
    The other pins depend on what software your gonna use, but they go to a db25 connector.
  18. SteveyG
    23 Nov 2002
    I think he wanted a variable brightness backlight using a 100 ohm pot. Obviously it's not required though.
    Just keep that 10 ohm fixed resistor in there and you're fine :)
  19. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    ya ill probly get the resistor too
    Mainly because at digikey id be getting a 10k and maybe the 100ohm pot which are 89 cents each, and then the shipping is like 5 bucks, theres no way in hell im gonna pay 5 bucks to ship 2 tiny lil thangs haha
  20. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    hmm digikey doesnt have a 10ohm resistor in stock, and the one they do have is 1k watt would it still work?
    gfuess i cant get a resistor, so i just gotta get the pot
    edit: the 100ohm is out of stock too, can someone give me links to the parts at another site, i dunno where to look on all-electronics
