Modding Need help with plexi frosting
Discussion in 'Modding' started by pr0xZen, 5 Nov 2004.
  1. B3CK
    B3CK Minimodder
    14 Jun 2004
    I know this is an older thread, but I have and do, frost plexiglass. The best way to get an even frost, and not "harm" the plexi is this: Buy yourself a can of clear "wood" based acrylic sealer/clear coat and spary one side of it lightly. Wait until it drys, do not soak the plexi with it. Re-aply light coats for a thicker frost. It will take about 10 min per frost. Easy, simple, and when working with plexi, a very fast option. I have noticed that it does work best on flat peices, so if you have heated the plexi for bends, it might not be such an even frost on the bended areas.
    Hope this helps.
  2. pr0xZen
    pr0xZen What's a Dremel?
    5 Nov 2004
    I have thought several times about going with such or plexi spray frosting - though the reason I have not done this yet, it that that I wasn't looking for just the matte look, I was looking for the effects it has when lighting up the plexi. It's to be behind a cut motive in my door, and the entire plexi is to be frosted. Would sprays and such, have this effect also? As far as I know, the effect is caused by light being refracted. The sprays and coating, as well as "etched appliqes" would would just partially *dim and diffuse* the light.
    Would be nice to know before I spent more money on this, it has costed me much more now, than buying new plexi and having it sand blasted.
  3. Emon
    Emon What's a Dremel?
    14 Jun 2004
    If the ENTIRE peice is to be frosted, just by frosted plexi...
  4. pr0xZen
    5 Nov 2004
    This was of course my first thought, but there's two aspects that counter this.
    1. It's hard to get around these parts. Plexi in general is hard to get here.
    2. This will not be the only work I do on plexi, so I see it highly neccessary to learn how to do this successfully.
  5. Emon
    14 Jun 2004
    Try brake cleaner, just be sure to fit it with a spray painting nozzle, as the nozzle on brake cleaner makes heavy streams, as it's made for cleaning brakes.
  6. Kickn
    Kickn What's a Dremel?
    7 Oct 2003
    i've just been playing wiht some material and if your going to blast it then I think you should try aluminium oxide. I don't have any but what i did have (glass bead/etc) wasn't abrasive enough to give a good frosting.
    I've got a can of spray drying so I'll let you know how that goes.
  7. pr0xZen
    5 Nov 2004
    How did that spray work out? Had to buy some new plexi, the old one was totally ruined by the numerous attempts to frost. Had a chat with the guy at the local "glassmaker", he was going to charge me 250 NOK (About ... $40) to blast one side of a 13*40 cm piece of plexi. F*ck me! Thats like... about 7 tmes what I paid for the plexi. DAMNIT!
  8. Emon
    14 Jun 2004
    :eeek: Glass wasn't abrasive enough on a SOFT PLASTIC? You're kidding...maybe the beads were too big or you weren't patient enough. I used a very fine play sand. It takes time, but is very even and soft.
  9. pr0xZen
    5 Nov 2004
    The glassmaker told me some of the reason for the high charging, was that plexi is really hard to blast. Lexan, being softer, is even worse. If the beads are "too smooth", it will take ages to blast. Plexi has a much softer surface than metal and glass. This, although exaggerating - is like trowing a rock at a rubber plate. You can mar the surface - but it will definetly take some time. If using matals to blast, it could work faster - but you might get a discolored surface.
  10. Emon
    14 Jun 2004
    Oh, true...well in that case, just use sand.
  11. pr0xZen
    5 Nov 2004
    Well, blasting is out of the question, atleast for me. I cannot afford it. I'm having a go with 60 grid paper now, actually it looks like it might just work... Now I just have to take a break from the sanding, my fingers have lost alot of skin from the 60 grid. Damnit, wish I could afford an orbital sander.
  12. case-graphics.co.u
    case-graphics.co.u What's a Dremel?
    12 Nov 2004
  13. THDBASED
    THDBASED What's a Dremel?
    30 Dec 2003
    Does anyone know a website where they sell frosted plexi?
  14. justinr54321
    justinr54321 What's a Dremel?
    10 Nov 2004
    Well, wet sanding to frost plexi has never worked, but you can use 100 to 120 grit to get a frost affect, don't use to heavy of pressure when using a sanding block, and you want the unfrosted side looking out towards you. I have a friends that does etching and frosting with plexi, and she uses 100 to 120 grit to frost it, with light pressured strokes. And you can try different techniques to get different frosted looks. Use some scratch plexi and experiment.
  15. djtitan
    djtitan What's a Dremel?
    18 Aug 2004
    Easyist way that I have found is about 2 minutes with an orbital sander at about a 300-400 grit. Is not exactly the same as a perfect frost with a sandblaster, but it has worked really well for me so far.
  16. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    i use a Profile Sander for most things that i would normally use a Random Orbital Sander for, mostly because i dont have an ROS...is there much of a difference? the end result always comes out the same, sometimes even looking better than examples ive seen done with an ROS, but...concensus?
