Build Advice Need More Speed
Discussion in 'Hardware' started by okenobi, 21 Jun 2015.
  1. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    My housemate runs Windows 7 on the following:
    C2Q 8400
    8gig
    Samsung EVO 840 120gig
    He has a bunch of storage HDDs attached and uses uTorrent heavily. He says the system is becoming slow with browsing, general Windows usage, but especially when uTorrent is running (he does A LOT of seeding - over fibre). The HDD where he currently has his main download directory is from 2009 and is making noises like it might be struggling.
    I'm wondering how much difference a cheap upgrade will make. Any ideas?
    I'm wondering if the following individual changes would make a difference:
    1) Replacing the ancient HDD?
    2) Clean Windows install?
    3) Moving to DDR3?
    4) Moving to SATA III for both his SSD and a potential new HDD?
    Looking at benches, a C2Q 8400 would be beaten by a current Pentium, but not by loads and he'd lose 2 cores. That said, he doesn't game or work. It's a glorified media box with a browser basically.
    Would love your thoughts, as even a cheap CPU, RAM, mobo, HDD combo will run £250. Thanks.
  2. silk186
    silk186 Derp
    1 Dec 2014
    Replace a his HDD with one or two new HDD. I recently bought two 3tb Toshiba drives. If the SSD is sata 3 it could benefit from sata 3.if not it won't. RAM speed is unimportant. Clean windows install could help as well. Overclock if he hasn't already
