Networks Need some help with FireTV on VM Superhub to see files on a USB drive on Tp-Link router.
Discussion in 'Tech Support' started by keenan, 30 Dec 2017.
  1. keenan
    keenan Minimodder
    12 Nov 2013
    Ok, here goes...
    I am using my Superhub 3 to connect my FireTV, PS4 and Steam Link. They are connected to ports 2, 3 and 4. Port 1 is used to connect to a Tp-Link router to supplies to house with Wifi. There's also a 1TB external hard drive connected to the usb port on the Tp-Link router.
    FireTV -> Superhub3 -> Tp-Link -> USB
    I want to access to files on the Tp-Link USB from my FireTV connected to my Superhub3.
    Is there some special setting I need to change or enable on either to Superhub or router?
    Thanks to anyone willing to help..
  2. RedFlames
    23 Apr 2009
    Is UPnP turned on? IIRC most of that kinda think rely on it to see/find each other...
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Have you enabled Storage Sharing on the Tp-Link?
    Is the Tp-Link running in wireless router mode?
    Is the Tp-Link being picked up by the superhub?
