Overclocking Need some info on 4850's
Discussion in 'Hardware' started by Aragon Speed, 24 Jan 2009.
  1. Aragon Speed
    Aragon Speed Busily modding X3: Terran Conflict
    12 Jan 2009
    Hey everyone,
    Not sure this is in the right section, if it isn't can a mod/admin move it please. :)
    I am trying to OC my 4850 so it has a little more go in it, and I was wondering if I could get some info.
    If a 4850 and a 4870 use exactly the same GPU, why can the core speed not be raised to 4870 standards? Is it the PWM's? (Obviously you can't raise the ram to the same speed as it's only DDR3, but in theory the GPU core should raise to the same speed that a 4870 can handle.)
    I have a custom cooler on my GPU, and at stock speeds it only hits 49 degrees when under full load, so I should have plenty of OC room. Problem is I can only get about 12 MHz out of it before it becomes unstable. I think it may be a lack of power, is there a tool about that allows tweaking of the GPU voltages?
    Any general advice (Apart for take it easy, which is obvious. ^^) about OC'ing a GFX card would also be appreciated. :)
  2. Guest-23315
    Guest-23315 Guest
    4870 uses GDDR5 IIRC.
  3. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    There's no soft way to change GPU voltages - extensive hardware modding (replacing resistors with variable ones etc...) is needed to raise them.
  4. Aragon Speed
    12 Jan 2009
    Yeah it is, which is why I mentioned the GDDR 3 not being able to make it, but the GPU clock should be able to in theory.
    I was thinking of a way to tweak the voltages in the cards BIOS actually, I'm not so noob that playing at that level bothers me. lol
    Probably need something like this: http://www.techpowerup.com/downloads/1283/TechPowerUp_Radeon_Bios_Editor_v1.18.html
  5. Diosjenin
    Diosjenin Thinker, Tweaker, Et Cetera
    14 Jul 2008
    Ehhh... you'd be safer going with something like ATITool. It will automatically and gradually OC the core for you until it starts artifacting - thus it gives the highest core OC guaranteed safe for your card every time.
    - Diosjenin -
    Aragon Speed likes this.
  6. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    how hot is your card getting? I can max out my core and it still runs. But I have an aftermarket cooler.
  7. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    I haven't fiddled with a GFX bios since nvidia 6800GT days, i had my overclocked for so long i thought 435Mhz was the stock speed!
    It might just require a little boost in GPU voltage in order to get 4870 speeds, as all 4850's are just poor performing 4870 cores, hence the underclock.
  8. Aragon Speed
    12 Jan 2009
    38 degrees C at idle, and 49 after 10 mins at full load at stock speeds.
    After a lot of fiddling I have managed to OC it too 665 core and 1038 GRAM before it starts to be unstable. At those speeds the card gets to 58 Degrees C after 10 min fully loaded. Air Cooled.
  9. tonpal
    tonpal What's a Dremel?
    27 Jul 2008
    Overclocking levels are never guaranteed. The frequency a piece of silicon can support varies and as a consequence this produces the headroom used for overclocking. The better silicon will be used to produce 4870 so although you have the same GPU the particular chip you have may not be able to support 750MHz.
    You may have to face the fact that the particular chip you have is a poor overclocker.
