Motors Need to get my grey bumpers black
Discussion in 'General' started by mushky, 26 May 2005.
  1. mushky
    mushky gimme snails
    24 Mar 2003
    I need something that can turn grey bumpers black. Would vinyl dye from halfords do that?
    I can't use back to black cos that just makes the bumpers look shiny grey, not black.
    Any suggestions chaps?
    Cheers.
  2. :: Phat ::
    :: Phat :: Oooh shakalaka!
    7 Jun 2002
    BBQ Spray Paint.
    Honestly, Did my old corsa with it at least 4 years ago, still looks like new today.
  3. Dad
    Dad You talkin to me?
    15 Apr 2003
    I wouldn't think that kind of paint would last to be honest. My first choice would be a good vinyl dye from a auto-body supply shop.
  4. mushky
    mushky gimme snails
    24 Mar 2003
    Do you know if you can get something that I can apply with a brush or sponge? If I used a spray can I know I would get it everywhere. The bodywork is white so I need to be careful.
  5. Dad
    15 Apr 2003
    I would think that you could get something like that. I'd seriously go to an auto-body supply shop and tell them what you're doing and what your concerns are. They've more than likely run across other people who have the same concerns and can suggest a solution.
  6. fev
    fev Industry Fallout
    13 Aug 2003
    the product is called....wait for it....
    back to black! works wonders
  7. Dad
    15 Apr 2003
    Not on grey bumpers.. My Volvo 850 has grey bumpers and the only thing that back-to-black does is to make them streaky.
  8. mushky
    mushky gimme snails
    24 Mar 2003
    Read the post mate :rolleyes:
    That sounds like good advice, and that's what I'll do. Cheers Dad ;)
  9. fev
    13 Aug 2003
    ooops
  10. :: Phat ::
    7 Jun 2002
    Dad - You'd be supprised! BBQ paint is excellent for the job! It bonds together to form a coating, even used it in my mums fireplace where the flameproofing had been chipped off!
  11. Will
    Will Beware the judderman...
    16 Jun 2001
    Halfords black bumper paint :thumb:
  12. Hiren
    Hiren mind control Moderator
    15 May 2002
    I used cooking oil once and it works remarkablly well. It was on my old 1.2 Corsa and plus it was cheaper than paint.
  13. tsa cain
    tsa cain What's a Dremel?
    14 Mar 2005
    REALLY?? i used it on my nissan frontier and it made the bumpers look brand new
    you have to clean it,rub it in real good, then buff it with a cloth..
  14. Dad
    15 Apr 2003
    Eh, I prolly just didn't want to spend that much time on it. I've used the stuff which is designed for grey bumpers and it's very easy and takes no time at all. It's like they say: "work smarter not harder" ;)
    Not saying it won't. I'm just all for using the right "tool" for the job is all..
  15. :: Phat ::
    7 Jun 2002
    It'll protect your bumpers from a fire :p
    Imagine, that, the car is toast except for a couple of pristine bumpers sitting each end of a pile of ash :D
  16. mUrml
    mUrml What's a Dremel?
    13 Jan 2005
    Well I would personally remove the bumpers from the car prior to painting.
