Modding Needing a Articulated Arm for LCD
Discussion in 'Modding' started by MiLwOrkZ, 1 Nov 2005.
  1. MiLwOrkZ
    MiLwOrkZ What's a Dremel?
    6 Feb 2005
    Hey gu7yz need some quick help i need an arm that can reach an approxamately 36" minimum to about 48" ... It is going to be mounted on a headboard for an overhead lcd display! No ceiling mounts.... it needs to be able to be upgradable to adapt to 2 lcd dispalys...
    tahnks for the quick replys...
  2. mattthegamer463
    26 Nov 2004
    you might find some sort of lamp that has a arm like that. i think thats your best bet unless you want to make it yourself or try and custom order something.
  3. MiLwOrkZ
    6 Feb 2005
    yeah but it has to hold 2 lcd's i think i might jsut manufacture one... jsut dont want to spen the $600 on one that wont even do what i want.
  4. mattthegamer463
    26 Nov 2004
    wait, how big are the lcds? you talking like massive 19" ones, or little 5" ones? i dont think i understood properly what your trying to do.
  5. Nexxo
    23 Oct 2001
  6. woof82
    woof82 What's a Dremel?
    18 Jul 2005
    Cant you just pull apart an angle-poise lamp?
  7. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    yeah, if you replace the springs on an anglepoise lamp with stronger ones, and fabricate a monitor mount to replace the lamp part, it should work
  8. MiLwOrkZ
    6 Feb 2005
    dual 19 viewsonics VX924's will be mounted so has to be surdy! it will be mounted to a head baord and then go over the person head so they can sit and bed and have monitors right in front!
