News Nehalem and X58 show up in Taipei
Discussion in 'Article Discussion' started by Tim S, 30 May 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    ditch the legacy already (apart from PS2!!)
  3. kenco_uk
    28 Nov 2003
    Strange that, if the main chipset chip runs so much hotter, that there's not a crazy heatpipe configuration bolted on.. or even a fan.
    And what's the deal with the heatsink in a box? Looks kooky, but if it's what to expect.. hmm!
    Exciting though :)
  4. Tim S
    Tim S OG
    8 Nov 2001
    I'm pretty sure the blue box is the space they have to leave around the socket (for installing 3rd party heatsinks). It'll be Intel's minimum spec for free space around the socket.
  5. Guest-16
    Guest-16 Guest
    Don't read into the cooling too much it's very much a "test board" - those DrMOS power phases need cooling too I'd think. :) It's a shame I couldn't see one fired up though :( apparently the CPUs are very, very scarce on a per-company basis and are in constant use.
    It was surprised at the chipset too - but it makes sense given its size (it looked significantly bigger than P45 which is 65nm too) and the tons of super-fast frequency links it has to cope with.
    Yea, the big blue block is the reference motherboard manuf. (and case etc) need to adhere to to leave completely free - so capacitors and other components don't get in the way.
  6. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    clever thing that :)
    It would be a nice stunt to get a hold of one of those and build a pico-ITX system inside of it :D
  7. naokaji
    naokaji whatever
    8 Dec 2006
    big keepout area = good, no more trouble with big aftermarket coolers, wooot.
    I dont get it why they dont want to drop the legacy crap though, I mean seriously, you cant even buy devices anymore that use them for several years now (talking consumer market here, servers are a different thing, but they get different mainboards as well so it doesnt matter).
  8. wyx087
    wyx087 Multimodder
    15 Aug 2007
    nice backplate :)
    i hope Thermalright's Ultra 120 Extreme is just a bracket away from this new socket.
  9. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    uh, triple channel memory? what's the deal with that?
  10. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    hmmm to get p35 and wolfdale now or wait till nehalem and x58 are affordable
  11. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    2+1?
    As for legacy ports, you'll always have some prat that doesn't want to sell his Parallel-based printer. At the end of the day, if it works well, then fair enough. But if it really does work that well then buy a cheap Parallel print server, OR spend a similar amount of money on a PCI/PCI-E Parallel card.
    Fortunately (in most cases, though quite the opposite here) it doesn't matter if you're a tiny minority when you're complaining to companies. "Oh noes, angry users!" :wallbash:
  12. phuzz
    phuzz This is a title
    28 May 2004
    @Denis iii
    buy now, wait until the second generations of Nehalem and motherboards come out and some of the issues have been ironed out.
    Otherwise you'll end up stuck with another Socket 754 (the first gen of Athlon64's which were pretty soon superseded by 939), and trust me, that's annoying.
  13. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    ya I agree with MSI, they should drop at least the floppy seeing how you can use USB floppy drives, I also think the ps2 ports should be dropped as well, I think IDE should probably stick around a little longer maybe just one of then even though I havent used it in a few years.
  14. Nikumba
    Nikumba Minimodder
    29 Aug 2001
    Ditch parallel, floppy, but keep PS2 ports
  15. Multiplectic
    Multiplectic His Stigness
    4 Sep 2007
    Me too. It would be a shame to ditch a perfectly capable HS because Intel changed the mounting holes' distance.
    Tim, are you sure the mounting is different? :(
  16. virtualrain
    virtualrain What's a Dremel?
    28 Jul 2006
    Great early look at the Nehalem platform!
    They need a third color of DIMM slot for the third channel... Right now it looks like dual channel with three slots per channel rather than the other way around.
    Also, aren't the extra 4x PCIe lanes in the X58 used for the link to the ICH10 SB? Traditionally, the DMI link from NB to SB is 4x PCIe... More info on Nehalem and X58 here... http://www.nehalemnews.com/2008/04/nehalem-faq.html
  17. Vigilante
    Vigilante What's a Dremel?
    30 May 2008
    "MSI also includes six memory slots because the CPU has triple channel DDR3, and exclusively DDR3, so you’ll have to buy at least three DIMMs to make the most of the new upper-tier Intel platform."
    I think you'll find that's because it is. Except It's not dual channel with three sticks, it's triple channel. It's the performance advantage DDR3 has been needing to ensure uptake, now if only it drops to semi-decent levels. It doesn't need to be awesomely cheap considering the performance advantage triple channel memory would have over dual channel, since enthusiasts would be more than willing to pay a price premium.
  18. ssj12
    ssj12 Minimodder
    12 Sep 2007
    Windows Vista doesnt have a floppy drive standard in the OS does it? If I remember it doesn't so drop it since even M$ dropped it.
  19. Icy EyeG
    Icy EyeG Controlled by Eyebrow Powers™
    23 Jul 2007
    This may be a bit retro, but triple channel can be a good thing for 32-bit Windows users, as you can put 3 Gb of RAM on the system, instead of 2 or 4 Gb.
  20. bowman
    bowman Minimodder
    7 Apr 2008
    32bit OS and Nehalem is like a black-and-white 1080p television.
    Really, 64bit Vista is mature now. Time to let go.
Tags: Add Tags
