News NetSpectre vuln allows remote Spectre exploitation
Discussion in 'Article Discussion' started by bit-tech, 27 Jul 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Holy Grandmother-of-All-Vulnerabilities, how?! How do you read memory contents over the network?
  3. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    Probably with quite a lot of luck I would imagine, surely address space randomisation means that data rarely gets stored in the same place twice?
  4. Gareth Halfacree
    4 Dec 2007
    I refer you to Section 5.2 of the linked paper, 'Remotely Breaking ASLR [Address Space Layout Randomisation] on the Target System.'
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    It is explained at the bottom:
    Translation:
    The basic access restrictions which are used as a foundation to build security on have been swallowed by a sink hole named Spectre and not installing the updates to plug that hole is about as responsible as announcing on facebook that you will be on holiday next week and that the key is under the door mat.
    Gareth Halfacree likes this.
  6. adidan
    25 Mar 2009
    I'd feel more secure if Asus had a more recent bios than 2016
  7. B1GBUD
    29 May 2008
    Well of course I didn't read the paper silly!
    So you'd still need a lot of luck.... no? And leaking at a rate of 15 bits per hour?
    https://www.theregister.co.uk/2018/07/26/netspectre_network_leak/
    edzieba likes this.
  8. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    The main upshot of the discovery of SPECTRE class attacks is to add one more thing you need to consider when hardening your software (alongside "don't try and read from empty buffers" and "don't try and write to full buffers"). Removing Speculative Execution from CPUs is about as likely as removing internal caches. You can technically do without it, but you won't like it.
    B1GBUD likes this.
  9. jb0
    jb0 Minimodder
    8 Apr 2012
    As hilarious as that is, the pedant in me insists on pointing out that you can have branches without speculation. The 486 that Doom targeted was such a processor.
    So it will indeed be devastating to performance, but more like fifty percent than fifty-thousand percent.
  10. Alecto
    Alecto Minimodder
    20 Apr 2012
    But, but ... I'm only leaving for vacation the week after?!
Tags: Add Tags
