Networks Network Idea
Discussion in 'Hardware' started by kbates666, 17 Jul 2006.
  1. kbates666
    kbates666 What's a Dremel?
    24 Jan 2006
    Ok, I have set up standard networks before but I wanted to know if this is possible. Ok I have a 2 wire modem router combo and I access is with a USB HPNA adapter (works surprisingly well). I have been sharing my internet connection with the motherboards NIC to share with my second PC(straight cat-5 pc to pc connection). I have had my hands on a old computer I plan on using for a file server and I would like to also share my internet connection with it. So I have a NetGear MR314 wireless router and want to use it as a mediator inbetween the PC's. Will this work?
  2. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    Yes it will work, but why don't you just take the computers and plug them into the router/modem combo NIC slot, that is if it has a builtin switch, if it doesn't just take a wire from the NIC port on the modemrouter and plug it into a LAN port of the Netgear router, and then plug a network cable in the other ports and into the other computers.
  3. kbates666
    24 Jan 2006
    Well I'm in another room from my modem/router combo thats why im using the HPNA adapter.
    Its like this:
    Click Here
  4. kbates666
    24 Jan 2006
    Ok will this work
  5. kbates666
    24 Jan 2006
