Networks networked storage
Discussion in 'Hardware' started by darklord, 13 Oct 2004.
  1. darklord
    darklord What's a Dremel?
    12 Jul 2003
    is there a way to attach a hard disk to a network without paying the price and without a whole computer too???
  2. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    Not that I know of.
    You don't need a powerful computer for a network storage server. Any old system will do...may be a bit slow, but functional.
  3. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    you don't need much to get it running... a PSU, a mobo (with onboard graphics could be practical) and the hardisk(s) you need "networked" (and a cool case to put it in, of course)...
    just get it running and use realVNC or something similar to controll it...
    i have a computer set up like that (it have a soundcard and a cd ROM aswell though..) alltough it's not used for storage on the network (i have a couple discs in my own comp. for that)...
  4. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    do you want a hobbiest micro electronics awnser?
    If so then yes, but you need a high end micro such as an ARM710. A prototype board would cost about as much as an old mobo with onboard gfx + video + lan.
  5. SilentDeath
    SilentDeath What's a Dremel?
    28 Jun 2004
    I had this same idea about a week ago, but don't really have the funds to go through with it. Here's what I was thinking:
    Use a Geode-based system to control the hard drives. Something like the Soekris net4501, with a PCI controller or raid card, running Linux. To map it as a drive in WIndows, you'd probably have to write your own protocol, but if you could get it right, such a thing would be handy.
  6. Firehed
    15 Feb 2004
  7. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    once running linux, could use samba, but for the cost of that, why not just get a passivly cooled, nano, or mini itx board.
    heck the mini-itx box that has just 12v input should only set you back £100 at most. It would also have nice hardware vid decodoing, and other nice things.
  8. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    These are about $100 cheaper than the earlier mention NAS, but it is 40 GB less.
  9. solar
    solar What's a Dremel?
    6 Mar 2004
    You could get one of these from Linksys - £71.99 on Dabs. You'd then need a USB2 caddy for your hard drive - perhaps £20-30. So you should be all sorted for under £100 (assuming you already have the drive of course...)
    Jamie
  10. SilentDeath
    28 Jun 2004
    Hmm, indeed. I never thought about mini-ITX, but now, this is looking a little more viable. Thanks. :D
  11. nleahcim
    nleahcim What's a Dremel?
    22 Apr 2003
    That's what I was going to reccomend. Also this Netgear router: http://netgear.com/products/details/WGT634U.php allows you to plug in a usb 2.0 drive as well.
    You could also get a Rio Karma - it has ethernet connectivity, though I'm not quite sure of the details of it.
  12. darklord
    12 Jul 2003
    thanks for the help guys i've just noticed that this post should have been in the networking section but as I have a usb 2 external HD I will most likly go for the linksys solution
  13. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Well, if you're not going to use an ARM or solder anything we'll send you packing... :thumb:
  14. theshadow27
    theshadow27 What's a Dremel?
    23 Sep 2004
    do you think that you could change the HD in this without a problem? like take out the 160 and put in a 250/300? and if it uses IDE inside, could it support 2 drives?
    or is the only way to find out to take it apart...
  15. hk
    hk Powered By Duracell
    4 Jul 2002
    Old computer dude... simplest cheapest way.
  16. Edwardyh
    Edwardyh What's a Dremel?
    24 Sep 2002
    ok...i have a few old mobo's (P1's @ 166-233Mhz) now my question is, is there any kind of distro that i can jsut install and it makes the system jsut like a network storage device? i dont wanta install SuSe or so cuase it will take up alot of space on usless software.. (o it the network is mostly win2k, and xp systems).
  17. ZeroX
    ZeroX What's a Dremel?
    17 Sep 2003
  18. ChegsJAR
    ChegsJAR What's a Dremel?
    7 Sep 2003
    slackware 10 all the way
  19. Edwardyh
    24 Sep 2002
    Thanks ChegsJAR, downloading slackware as of lastnight (cd1 finish, cd 2 over 50% done)
  20. ChegsJAR
    7 Sep 2003
    slackware comes with a web-based package called SWAT.
    Run this and it will set up samba for you. :D
