new build - no video output? - HEEEELLP!!! :( ...still no luck
Discussion in 'Tech Support' started by webbyman, 20 Aug 2006.
  1. webbyman
    webbyman Hax.
    7 Oct 2004
    system specs:
    am2 x2 3800+
    enermax 485watt psu
    gigabyte geforce 7300 gs
    Asus M2N-E mobo
    samsung spinpoint 80gb ide drive
    2x 512mb corsair ddr2 pc5400
    generic dvd rom drive
    when i connect everything up, the motherboard light turns green, i hit the power switch cpu fan spins up, mobolight stays green but nothing appears on the screen :/ tryed my gfx card too a 7800gtx but with no luck, anyone got any ideas why theres no output :( ?
    thanks in advance :]
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Have you checked all the connections? Is the motherboard grounding on anything? Tried with just the bare minimum - i.e. one stick of RAM etc?
    Do you get any error codes or beeps from the motherboard?
  3. webbyman
    webbyman Hax.
    7 Oct 2004
    been trying it with just the bare minimum, haven't recived any beens or signals and im pretty sure the speaker is connected properly....
    only thing i need to check is weather it's grounding on anything :O
    I think I will take it out of the case and place it on some carboard for a tester....
    Any other suggestions :(
    and thanks :)
  4. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Only to rechect all conections.
    BTW are you using a monitor or an lcd?
    My mb was set to monitor so when i conected to lcd i saw absolutly nothing.
  5. Pookeyhead
    30 Jan 2004
    Dont lie the motherboard on an antistatic bag. Most think this will give protection, but in fact, the outside of a anti-static bag is conductive, and using it as a mat to lie the board on when powered up can, and indeed probably will, short something out.
  6. webbyman
    webbyman Hax.
    7 Oct 2004
    just tried it layout on a wooden desktop, still frantically trying :( no luck.
    someone PLEAAASEEE HELP!
  7. DougEdey
    5 Jul 2005
    The reason why you aren't getting any beeps is because you are running bare minimum. Get the PC speaker out of a case and put it on the board.
  8. webbyman
    webbyman Hax.
    7 Oct 2004
    cheers will try, i kinda ignored that i think as my dfi's got an onboard one, need to hunt one down, also the light stays green so i assumed it was oook lol just dead something?
  9. DougEdey
    5 Jul 2005
    It depends on the beeping, have you tried a new graphics card?
  10. webbyman
    webbyman Hax.
    7 Oct 2004
    tried a different gfx card and theres no beeps!
    help :( it's been ages :/
  11. EK-MDi
    EK-MDi What's a Dremel?
    12 Mar 2006
    I've got an idea... Check to see if the 12V voltage connector is actuall connected. I once had the same problem as you, and replaced everything, and I mean EVERYTHING. Then I had one last look before I started tearing my hair out, to find that I failed to connect the 12V voltage connector to the motherboard.
  12. webbyman
    webbyman Hax.
    7 Oct 2004
    checked the 12v :]
    might try a complete power supply, re sit cpu then a few desperate ideas...
    then im going to rma the motherboard? as this is a joke :/
  13. Springs
    Springs Boing boing
    29 Aug 2004
    dont suppose u have a pci GFX card u can try...? paybe its ur PCI-e port?
  14. Lakeuk
    Lakeuk What's a Dremel?
    28 May 2006
    I had the same thing a couple of weeks back when biulding my E6600, I hadn't connected the ATX_12V plug the the motherboard - thought it was only needed for the GCard, search of the net put me right :clap:
