Motherboards New build starts up randomly...
Discussion in 'Tech Support' started by Cei, 29 Sep 2013.
  1. Cei
    Cei pew pew pew
    22 Mar 2008
    So, I've built an ITX rig and it's lovely. However, it has one little quirk - namely booting up all by itself after a clean shut down. It won't do this straight away, but might take 15-30 minutes to do so, and boots straight in to Windows 8 and sits there as if I had pressed the power switch.
    I've flicked through the EFI and had a poke around Windows to see if I can find anything that might be causing it, but currently not. The only solution is to turn the PSU off directly right now. Any ideas?
    - ASUS Maximus VI Impact
    - Intel i5 3670K
    - 8GB Corsair Vengeance LP 1866Mhz
    - Samsung 840 EVO 128GB
    - EVGA Hadron Air w/ built in 500W Gold PSU
  2. tuk
    tuk Don't Tase Me, Bro!
    28 Oct 2012
    Disconnect power switch from mobo ...does it still do it?
  3. Cei
    Cei pew pew pew
    22 Mar 2008
    Good shout, will give it a go!
  4. suragh
    suragh Minimodder
    26 Nov 2011
    This happened to me when I had wake on LAN switched on in the BIOS. Try switching it off and see if that helps.
  5. Cei
    Cei pew pew pew
    22 Mar 2008
    Would WoL actually start up a computer from being turned off? (Not in hibernation/sleep) And over WiFi, not ethernet?
  6. workingclass
    workingclass What's a Dremel?
    17 May 2010
    Had that also a long time ago from Wake on Lan. Worth trying to turn it off.
  7. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    it can yes
  8. itrush07
    itrush07 Minimodder
    28 Nov 2007
    Im also interested on how to get rid of this error, please update us guys..
  9. Cei
    Cei pew pew pew
    22 Mar 2008
    Okay, so WoL was off already, but I've adjusted settings for rebooting on power failure that seem to have achieved something - it's been off for 4 hours now and counting.
    EDIT: Dagnabit, it booted up. Need to try Tuc's idea of disconnecting the power button.
