So the long and short of it is ive moved my folding rig into a new case (three hundred) and had to move my 3 gpu's form slots 1 2 and 4 to 1 2 and 3 because of the psu! But now im only getting 3253PPD out of the card in slot 1 where as before i was getting 6600PPD same card same slot! I cant figure out why im getting half points!! Ive checked the flags, targets and ID's and reset multiple times and cant figure it out! ANY ideas guys im dropping 3000PPD ATM
The card is in the same slot as it was to start its the 3rd gpu thats moved from slot 4 to slot 3 this is GPU1 in the primary pci-e slot. temp is about 85c they tightly packet in so thats why so hot but thats around the same temp as before. doing 353 pointers. Im gunna move the cards around a bit and see what happens Edit: Ok that worked now got gpu1 where gpu 2 was and its fine! wired... so now i need a single slot folder for my last pci-e slot was thinking 9800GT? finding one is hard tho
I have a 8800gt I was gonna put on ebay doing 4500 points per day overclocks like crazy. £50 posted. Mike [13:11:11] + Processing work unit [13:11:11] Core required: FahCore_11.exe [13:11:11] Core found. [13:11:11] Working on queue slot 06 [December 21 13:11:11 UTC] [13:11:11] + Working ... [13:11:11] [13:11:11] *------------------------------* [13:11:11] Folding@Home GPU Core - Beta [13:11:11] Version 1.19 (Mon Nov 3 09:34:13 PST 2008) [13:11:11] [13:11:11] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86 [13:11:11] Build host: amoeba [13:11:11] Board Type: Nvidia [13:11:11] Core : [13:11:11] Preparing to commence simulation [13:11:11] - Looking at optimizations... [13:11:11] - Created dyn [13:11:11] - Files status OK [13:11:12] - Expanded 46675 -> 252912 (decompressed 541.8 percent) [13:11:12] Called DecompressByteArray: compressed_data_size=46675 data_size=252912, decompressed_data_size=252912 diff=0 [13:11:12] - Digital signature verified [13:11:12] [13:11:12] Project: 5767 (Run 12, Clone 33, Gen 1343) [13:11:12] [13:11:12] Assembly optimizations on if available. [13:11:12] Entering M.D. [13:11:18] Working on Protein [13:11:19] Client config found, loading data. [13:11:19] Starting GUI Server [13:12:41] Completed 1% [13:14:04] Completed 2% [13:15:26] Completed 3% [13:16:49] Completed 4% [13:18:11] Completed 5% [13:19:34] Completed 6% [13:20:56] Completed 7% [13:22:19] Completed 8% [13:23:41] Completed 9% [13:25:04] Completed 10% [13:26:26] Completed 11% [13:27:48] Completed 12% [13:29:11] Completed 13% [13:30:33] Completed 14% [13:31:56] Completed 15% [13:33:18] Completed 16% [13:34:41] Completed 17% [13:36:03] Completed 18% [13:37:26] Completed 19% [13:38:48] Completed 20% [13:40:11] Completed 21% [13:41:33] Completed 22% [13:42:56] Completed 23% [13:44:18] Completed 24% [13:45:41] Completed 25% [13:47:03] Completed 26% [13:48:26] Completed 27% [13:49:48] Completed 28% [13:51:11] Completed 29% [13:52:33] Completed 30% [13:53:56] Completed 31% [13:55:18] Completed 32% [13:56:41] Completed 33% [13:58:03] Completed 34% [13:59:26] Completed 35% [14:00:48] Completed 36% [14:02:11] Completed 37% [14:03:33] Completed 38% [14:04:56] Completed 39% [14:06:18] Completed 40% [14:07:40] Completed 41% [14:09:03] Completed 42% [14:10:25] Completed 43% [14:11:48] Completed 44% [14:13:10] Completed 45% [14:14:33] Completed 46% [14:15:55] Completed 47% [14:17:18] Completed 48% [14:18:40] Completed 49% [14:20:03] Completed 50% [14:21:25] Completed 51% [14:22:48] Completed 52% [14:24:10] Completed 53% [14:25:33] Completed 54% [14:26:55] Completed 55% [14:28:18] Completed 56% [14:29:40] Completed 57% [14:31:03] Completed 58% [14:32:25] Completed 59% [14:33:48] Completed 60% [14:35:10] Completed 61% [14:36:33] Completed 62% [14:37:55] Completed 63% [14:39:18] Completed 64% [14:40:40] Completed 65% [14:42:03] Completed 66% [14:43:25] Completed 67% [14:44:48] Completed 68% [14:46:10] Completed 69% [14:47:32] Completed 70% [14:48:55] Completed 71% [14:50:17] Completed 72% [14:51:40] Completed 73% [14:53:02] Completed 74% [14:54:25] Completed 75% [14:55:47] Completed 76% [14:57:10] Completed 77% [14:58:32] Completed 78% [14:59:55] Completed 79% [15:01:17] Completed 80% [15:02:40] Completed 81% [15:04:02] Completed 82% [15:05:25] Completed 83% [15:06:47] Completed 84% [15:08:10] Completed 85% [15:09:32] Completed 86% [15:10:55] Completed 87% [15:12:17] Completed 88% [15:13:40] Completed 89% [15:15:02] Completed 90% [15:16:25] Completed 91% [15:17:47] Completed 92% [15:19:10] Completed 93% [15:20:32] Completed 94% [15:21:55] Completed 95% [15:23:17] Completed 96% [15:24:40] Completed 97% [15:26:02] Completed 98% [15:27:24] Completed 99% [15:28:47] Completed 100% [15:28:47] Successful run
I've had this, I seem to remember that it is all about the drivers, you can't just go moving them around. If you do you need to reload the driver. Try that.
That's probably the answer. I found that reinstalling the drivers after moving cards to different slots usually sets everything back to normal. In particularly stubborn cases sometimes you need to run DriverSweeper. I believe that drivers 191 and after no longer behave like this. Which drivers are you using? It's always useful to confirm/deny such uncertainties.
Using 191.07 Its been working fine for the last few days! But ill try that if i have the same problem again! Thanks guys.
