New computer, a few problems and questions
Discussion in 'Hardware' started by mm vr, 26 Aug 2008.
  1. wyx087
    wyx087 Multimodder
    15 Aug 2007
    do this for MOSFET cooling on TRUE:
    also try turn up p182's fan, see if your system have enough general air flow
  2. pistol_pete
    pistol_pete Air Cooled Fool
    7 Jan 2008
    Those are really extreme changes for MOSFET temp. One (possible) reason might be the heatspreader isn't on right. Give it a wiggle? Does it feel rigid? The thermal paste for it may have been applied poorly in the factory, all I can suggest is taking it (you'll need to remove the NB too) and re-applying thermal paste. This might not be easy though, as they look like they are held by pushpins, harder to work with than scews. I'd leave this as a last resort, if you can't find any other reasons.
  3. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Eh, the NB temp problem is kind of fixed now, I played the game today and it was just up to 50C, not a single degree more. I wonder what was going on yesterday. Thanks for the suggestions anyway. :)
  4. tonpal
    tonpal What's a Dremel?
    27 Jul 2008
    Have you updated the BIOS on the P5Q? I recall reading that the latest BIOS had issues with temperature sensors?
    May be worth a trip to the Asus forums to do some research.
  5. mm vr
    18 Nov 2007
    No, I haven't updated it.
  6. mm vr
    18 Nov 2007
    Yesterday I ordered a WLAN card (D-Link DWL-G510) and a fan to it. I thought about getting an Antec TriCool but they were out of stock so I got a Xilence RedWing 120. I looked for a fan with the specs of about the same as the TriCools have on medium and this was what I found.
    Code:
                       CFM          dB
    Antec TriCool      56           25
    Xilence RedWing    60           21
