Graphics New GPU under £400
Discussion in 'Hardware' started by wilkinson001, 8 Oct 2012.
  1. wilkinson001
    wilkinson001 What's a Dremel?
    24 Feb 2012
    Hi all, im looking at upgrading my sapphire 6850 1GB to something with a bit more oomph. I have £400 at the absolute maximum, and have no preference to amd or nvidia. My gaming resolution is 1080p and i primarily play FPS (Bf3, Arma 2, PS2). I also try and fraps some gameplay, but currently my GPU doesn't give enough Frames Per Second to play on high settings at 1080p. Also would it be worth investing in a newer 7200rpm hdd to record to, my current one is ageing a little so that may be bottlenecking the recording.
    Cheers
  2. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
    http://www.scan.co.uk/products/2gb-...-gddr5-gpu-915mhz-boost-980mhz-cores-1344-2xd
    I have this, I didn't think the top was worth the £50 extra ( this is already £50 dearer than the basic models but I like the cooler for looks and performance and it matches my cooler scheme)
    Some say it is overkill but I like to keep my GPUs for a minimum of 2 years and in that time it will age gracefully.
    I recommend it highly the with the spare cash grab on of these.
    http://www.scan.co.uk/products/128g...mm-sata-iii-read-520mb-s-write-320mb-s-pc-mac
