Build Advice New PC Build: Gaming / TSQL
Discussion in 'Hardware' started by Toka, 29 Nov 2011.
  1. Toka
    Toka Minimodder
    19 Nov 2006
    Hey All,
    Apologies for adding to the interminable list of build advice threads, but there are a couple of options that Im not sure on and could do with some extra input.
    Budget: £1500
    Main uses of intended build: Gaming / Visual Studio / Server Management Studio (TSQL Database stuff)
    Parts required:
    CPU: i7 2600K
    Cooler: Be Quiet Dark Rock Advanced
    Mobo: P67 - this one?
    Memory: 8GB 1600MHz
    GPU: GTX 570 (hopefully this one is nice and quiet)
    SSD: 128GB Crucial M4
    HDD: 1TB
    Case: Silverstone FT02
    Monitor: 1080p 23" IPS panel - this one seems popular here :)
    Wireless Keyboard and Mouse
    Previous build information (list details of parts):Im currently using a C2D/5870/2GB RAM, hoping to carry a couple of parts over into a new build and create a pc from the old bits for parents to browse the web with. Ill be stealing the 850W PSU from here, and I have a spare copy of Windows 7 already
    Monitor resolution: 1080p
    Storage requirements: I need at least 500GB, and unfortunately I cant carry the HDD over from my old build
    Will you be overclocking: Yes - looking for 4.5GHz from the 2600k
    TL;DR The 3 bits that I need extra help with are the mobo, case and gpu.
    I am a bit bewildered by the array of choices in mobos, in the end I just went for a Bit-Tech recommended one, as the MSI GD53 in the buyers guide seems a little scarce. All I need from my mobo are some SATA III decent overclocking and (the tricky bit) if possible the space to fit a second gpu in SLI at a later date.
    Ive gone for the FT02 case as I am not planning to watercool and all of the reviews that I have seen say it is a efficient and quiet case. I just want my case to help me make my pc as quiet as I can (I admit that the 4.5GHz overclock is a spanner in the works here). Can anyone suggest alternative?
    For the GPU I chose a quiet tripple slot cooler design, but Im thinking that if I added a second in SLI at some point then there would not be any space between the cards and one would run hotter and noisier than it should. Does anyone know of a GTX 570 with a quiet double slot cooler?
    Many thanks in advance - little jars of christmas chutney (home made - not yoghurt!) for helpful folks :)
  2. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    I think your wasting your money replacing the 5870 as mine still handles everything thrown at it. I'm Playing BF3 at 1680x1050 with nearly everything set to Ultra with out any issues. I would keep your GPU just now and keep saving and see what the next gen cards offer in a few months time as your card will easily see you through until then.
  3. SouperMatt
    SouperMatt What's a Dremel?
    10 Apr 2011
    If you do decide to go with a 570 I highly recommend the Gainward Phantom. Top card.
  4. bortak
    bortak What's a Dremel?
    20 Nov 2011
    +1 to that, the 5870 still packs a punch, I wouldn't bother replacing it, I can play 90% of games on max (1680x1050), and that's with CPU that doesn't even compare to the 2600K
  5. trig
    trig god's little mistake
    10 Aug 2006
    might want to opt for the z boards...plenty of features to make it worth a little more, and should be compatible for ivy bridge down the road...
  6. GeorgeStorm
    16 Dec 2008
    I upgraded from a 5870/6950 to a 570 Phantom and couldn't be happier, while it does outperform the ati cards, it's the noise and heat reduction that made it for me.
  7. bortak
    20 Nov 2011
    well obviously... going from 2 cards to one will be quieter and cooler lol, not to mention a reduced power drain.
  8. GeorgeStorm
    16 Dec 2008
    You misunderstand, I was only running one of those cards at a time, just had them both, swapped them between two systems.
  9. bortak
    20 Nov 2011
    ahh I get it, I'm guessing your ATI cards had the stock coolers though right?, either way they're not the quietest things ever ^_^
  10. GeorgeStorm
    16 Dec 2008
    Yes indeed, hence why I went for a non reference 570
  11. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Dont be buying a hdd just yet, prices are still way OTT.
  12. Toka
    Toka Minimodder
    19 Nov 2006
    Thats a great shout guys it has given me something to think about for sure :) PM me an address if you would like some home made christmas chutney - I have red onion marmalade, apple chutney, or apricot/prunes/dates/spices chutney.
    Ive also somehow managed to miss the gainward card (looks clean and quiet) so if I do upgrade now thats one for me to look for.
    HDD, unfortunately I have to buy as I plan to give the old pc to parents
  13. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    They are more than twice the price they were a month back, if you can use other storage in the meantime then do it and hang on for another month or so.
