Build Advice New Rig For Uni
Discussion in 'Hardware' started by Ending Credits, 28 Aug 2011.
  1. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    I'd like to get a new rig for uni to replace my slightly aging one. I am completely out of the loop though so I thought I'd ask for advice on here so here goes:
    Budget: About £600 to spend but can streach that if needs be. I think it should be enough though.
    Main uses of intended build: Gaming and a bit of programming as well as general useage. Needs to be fairly portable as I will be lugging t back and forth quite a lot.
    Parts required: Everything except the GPU but I don't want a sound card and I'm not particularly keen on an SSD.
    Previous build information: Phenom I 9850 x4 2.5Ghz, 4870 1GB, 4GB 1066Mhz DDR2, 1TB F3, 250GB WD, Coolermaster 620W M, Aplus Black Pearl
    Monitor resolution: 1920x1200
    Storage requirements: Not much, just enough for my games, I can use my F3 anyway.
    Will you be overclocking: I don't currently, but there's no reason why not.
    My plan was something like:
    570 - Already have
    2500K - £150
    S1155 Motherboard - £100-150
    8GB RAM - £80
    Antec 300 - £50
    PSU - £80-100
    1TB F3 - £40
    Cooler - £40
    Extras - £20
    OS - £60
    Total ~ £650
  2. Blazza181
    Blazza181 SVM PLACENTA CASEI
    19 Apr 2011
    I'd keep the HDD and PSU.
  3. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    8Gig of low profile 1600MHz corsair vengence ram is £50~ on scan, no need to spend £80. As for power supply a corsair HX650 would be the best around your budget though more than you'd need, not that I suggest against that, I bought my seasonic due to it's quietness at my load level. As for the rest i'd wait a week for bulldozer benchmarks before going intel. If bulldozer is crap then just go with your proposed build.
  4. sb1991
    sb1991 What's a Dremel?
    31 May 2010
    Depending on when you start at university, it might be worth waiting for AMD's Buldozer CPU to come out, if only because it might bring Intel's prices down. RAM is cheaper than you might think - 8GB is more like £35 - £45, which is nice. Also, you may well be able to get Windows free (if you're doing computer science/related), or at a significant discount (MS are selling an upgrade edition of W7 Pro for £30).
  5. Ending Credits
    4 Jan 2008
    I think it will be at the start of October although I'm not sure of the exact date yet.
  6. Farting Bob
    Farting Bob What's a Dremel?
    21 Jan 2009
    Get a 2500k and the cheapest Asus P67 board (cant remember the model number). Any P67 board is fine, i just like Asus. No need to spend more than the cheapest line of boards unless you have specific requirements.
  7. Jehla
    Jehla Minimodder
    8 Jan 2010
  8. Blazza181
    19 Apr 2011
  9. amppatel
    amppatel What's a Dremel?
    25 Aug 2011
    Have you looked at any laptops? Now you can get quite fast ones. Also my uni makes me empty my room every term and so a laptop is really the only option for me.
