News New techniques boost 3D printing speed a hundredfold
Discussion in 'Article Discussion' started by bit-tech, 24 Jan 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    That could be a serious game changer even if it ends up being a tenth of the promised speed upgrade. That could make vat bed resin prints vastly more viable outside of a niche selection of prototyping uses.
  3. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    The improved speed would need to offset the increased resin costs (due to the need for the specialised inhibitable photopolymer mix), which are already rather high for resin-cure 3D printers.
  4. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Neat. Now if someone could just combine the resin printer with the functionality of the latest CMYK FDM systems.
  5. edzieba
    14 Jan 2009
    I think they're mutually incompatible. This rapid resin bath requires a homogenous resin tank to 'lift' the part from, while selective deposition requires heterogenous deposition. Once you add the roving print-head to lay down a pigment, you may as well use that to lay down the substrate too and skip the redundant resin bath.
  6. Dr. Coin
    13 Sep 2013
    I realize that there would need to be significant change in the technology. Perhaps a resin that has pigment that can be selectively triggered prior to curing.
Tags: Add Tags
