Graphics New to CrossfireX GPU advice needed
Discussion in 'Hardware' started by acrasal.mills, 24 Sep 2012.
  1. acrasal.mills
    acrasal.mills What's a Dremel?
    5 Sep 2012
  2. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Things to keep in mind:
    - The two cards must be equal (the same model).
    - A single £60 card performs much better than two £30 cards.
    - That card doesn't even support CrossFire.
  3. mrMonkeyChunks
    mrMonkeyChunks EVGA Cheesecake
    4 Mar 2012
    What are you looking to do with this card? If you are looking to play games (particularly recent releases) I would suggest staying away from this card. The 5450 is the budget 5000 series card, designed more for video playback more than anything else.
  4. acrasal.mills
    5 Sep 2012
    It clearly states on the box in top right corner crossfire. That's why I asked.
    I would like to use it for triple screen gaming can you suggest an alternative card that would be suitable.
  5. mrMonkeyChunks
    4 Mar 2012
    mm vr is wrong in respect to the crossfire, this card does support it.
    I assume you are looking at triple 1920x1080 screens? well, here is a link to bit-techs review of the 5450 at only 1280x800 linky
    to properly support a decent surround set up and high settings you are going to have to spend quite a bit of money than £30 and you are better spending it on a single card rather than 2 less powerful ones.
    this is in the ball park of what you might want to look at.
  6. rollo
    rollo Modder
    16 May 2008
    You can link any 2 cards in the same series for crossfire, however they will Clock down to the slowest card, for example a 5870 and a 5850.
    For triple screen gaming the minimum card your after is the 7970 or a 670 680 if you want anything like playable FPS.
  7. jifbo
    jifbo What's a Dremel?
    23 Sep 2012
    Tom's hardware does a section on the best value graphics cards at various prices. They also suggest crossfire/SLI combinations which work just as well for the price.
    Further thoughts are that you need a motherboard capable of SLI/Crossfire, and a decent enough PSU to run both cards.
  8. Xaine
    Xaine Death... destroyer of brain cells
    19 Sep 2012
    While i'm just an observer, i've found this thread quite helpful thank you, especially the mention to Tom's hardware to comparison :)
  9. mrMonkeyChunks
    4 Mar 2012
    if you could give full details of your computer as it is at the moment that would be a great help too
  10. acrasal.mills
    5 Sep 2012
    My computer as stands is phenom II x4 oc to 4.1 GHz an Asus m4a88t-v evo mob 16gb corsair vengeance and an Asus 2gb GPU a few years old forgot model though. I'm looking for a new build though so current hardwares not relevent
  11. mm vr
    18 Nov 2007
    Fair enough, but I still don't see the point in running two such low end cards in CrossFire.
    As far as I know, if you want dual graphics cards for three monitors, you can't run the cards in CrossFire.
  12. acrasal.mills
    5 Sep 2012
    OK then this is all advice I need as I'm unaware or what will do as first the GPU buying
  13. Guest-16
    Guest-16 Guest
    What's your budget?
  14. acrasal.mills
    5 Sep 2012
    I don't mind how much as long as its a good card that can do the job. As I can always save up.
  15. mm vr
    18 Nov 2007
    What's your screen resolution? Which games do you play?
  16. Guest-16
    Guest-16 Guest
    5760x1080: Look at a GeForce GTX 660 Ti or GTX 670 range at least imo. That's HD 7870/7950 range.
    I've only tested our Tytan with GTX 680 in BF3 and a few other games, but I recon you could get away with 1-2 notches lower just fine :) I can't see another significantly GPU hardcore title hitting the market in the next 6 months tbh.
  17. acrasal.mills
    5 Sep 2012
    I have a 1920 x 1080 at the minute but will invest in a few more once I have GPU. Looking for it to play cod bo2 and similar games and also racing sims too with best graphics possible.
  18. Parge
    16 Jul 2010
    COD doesn't need much GPU horsepower at all.
    Why are you going SLI? A single powerful card will be a much smoother experience.
  19. acrasal.mills
    5 Sep 2012
    I was advice by a colleague to go sli but thought I would seek further advice before committing to it as I have always gone solo GPU in the past. I have been looking at the geforce 670 but found about a dozen varieties anyone able to explain the difference to me?
  20. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    coming from someone thats been running crossfire for quite a while now.... dont do it.
