Newbee First mod [Updated 11/05/03 New Mods More Pics]
Discussion in 'Project Logs' started by MeRviN, 19 Mar 2003.
  1. MeRviN
    MeRviN What's a Dremel?
    19 Mar 2003
    :p This is my first attempt at modding. These pictures where taken with my web cam so sorry about the quality as soon as I get a good cam I will update them. Mods Include side window, lots of blue LED’s, switchable fan speeds, blue hard drive light.
    Mods to follow top fan switchable psu fan speed and I am going to get my case sprayed not quite sure what colour yet though any way let me know what you think.:confused:
  2. Werksmini
    Werksmini What's a Dremel?
    12 Feb 2003
    I really like the look of the LEDs at the top pointing down. I also like the window design. I dislike looking at that empty space of my case.
  3. skywalker107
    skywalker107 What's a Dremel?
    17 Mar 2003
    you should change those 6 lights across the 5 1/4 bay to blue
  4. banished
    banished Necromodder
    6 May 2002
    Well done for a first case. I think you need a lighted case badge to balance the light effects on the front. :clap:
  5. the_secret
    the_secret What's a Dremel?
    29 Sep 2002
    -> nicely done :clap:
    -> love the window and the blue LEDs pointing down. :D
  6. Moreland
    Moreland banned
    16 Jan 2003
    So Blooooo :) i love those bl00 led downlighters, excellent first mod mate.
  7. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    Those LEDs pointing down on the front look great. My Q-tec case allowes me to do so, too. Maybe I will...
  8. [S]lammer
    [S]lammer Can't touch this!
    30 Sep 2002
    looks great, how many LED's did you use?
  9. Sardien
    Sardien What's a Dremel?
    11 Dec 2002
    niceeeee!
    Nice mod!! :jawdrop:
    Are those normal LEDs shining down, or Lazer Leds?
    Thanks.
    God Bless & Kind Regards,
    Richard :)
  10. pranks7er
    pranks7er mange tout
    25 Dec 2002
    i agree the two blue leds shinning down on the cd rom i might add two leds to my case case using ur idea
    great mod anyway
  11. wedgius
    wedgius What's a Dremel?
    26 Oct 2002
    That is not bad at all. :) Do you know what case that is?
  12. MeRviN
    19 Mar 2003
    Updates
    Hi i have just done some stuff to me case I have put 2 x 50mm fans in the front which are switchable between 12v and 5v and an 80 m fan in the top of my case. There is a total of 35 blue LED’s in my case. As for the make of case I do not know it was an unbranded one that only cost £25 ish.
    I was also wondering about LCD display or vacuum display and how I would go about configuring them and the types of software I will need if any one can offer any surrgestions please do so.
  13. JrRRr
    JrRRr Minecraft addict
    27 Mar 2003
    You got yourself a really nice project going on there! Fantastic downlights, real nice touch!!
    Are my eyes lying to me, or is that the first tower I've seen without any suspension between the front and the back of the top part of the tower (power-side and drives-side)? (Maybe you just removed them?)
    Anyways - keep up the good work. :thumb:
    JRR
  14. banzai
    banzai What's a Dremel?
    29 Mar 2003
    Yes, the downlights on the upper part of the case are a great idea. Piccies with better wuality would also be nice :D
    :hip:
  15. skywalker107
    17 Mar 2003
    Good Call. What is the deal with no supports running from front to back on the top of that case.
  16. MeRviN
    19 Mar 2003
    There is a support if you look at the 8th picture up it is on the rhs of the case and runs just bellow the psu to my DVD drive :hehe:
  17. Bruno_me
    Bruno_me Fake-ad‎min
    30 Mar 2003
    you should check out Matrix Orbital matrixorbital.com they have all kinds of LCDs and VFDs and some usb models they have software that comes with it and download sites on their website. that's pretty much all I know of :clap:
  18. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    If you want to pay an arm and a leg!!!
    Check out http://www.crystalfontz.com/ while they are parallel, they are cheaper ;)
  19. JrRRr
    27 Mar 2003
    Yes, I saw that, I'm just not used to see towers without supports at the top. :eeek:
  20. MeRviN
    19 Mar 2003
    i am getting a fan bus made for me by a friend of mine that will let me switch beetween 5 volt and 12 volt, soon so there will be some more pics soon also i have added a clear fan to the top of my case with 3 blue led's in it i also want to make this some how Flashing LED's any idears???
