Newbie to folding
Discussion in 'bit-tech Folding Team' started by murraynt, 22 Jan 2011.
  1. murraynt
    murraynt Modder
    6 Jun 2009
    Hey guys. i want to start folding. I have the standard client installed at the moment but it is kind of hopeless.
    I want to fold with my 2500K and 275GTX. Can i use both at once? What clients do I install?
    Sorry if these questions sound completely stupid (I'm sure after a while i will be able to advise people on these sort of things).
    Is there a thread already dedicate to this? I thought there would be a sticky.
    Niall.
  2. paddi70
    paddi70 What's a Dremel?
    23 May 2009
    Hi, and welcome. This is a good place to be for folding and info of all sorts. You can use both at once, and should the GPU should not have a great impact on you CPUs folding.
    Use the following clients:
    CPU - SMP2 follow all instruction, you will need a pass key, and for the it run ten times before you get the big adv points. Thats an awesome CPU :) and will give you some good results.
    GPU - 6.23, as you have not got a Fermi card, so these work best.
    http://folding.stanford.edu/English/DownloadWinOther
    To monitor both use HMF:
    http://code.google.com/p/hfm-net/
    Instruction on setting up, are everywhere, but I found here good and simple to under stand for SMP:
    http://fahwiki.net/index.php/How_do_I_install_the_SMP_Console_client_in_Windows_7?
    I'm guessing your GPU is working fine.
    Again welcome, and I'm sure others will be along to say hi and give their own take on it all.
    murraynt likes this.
  3. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
  4. One_Box
    One_Box Folder of the month April 2012
    11 Jul 2010
    Welcome to the team, I hope you have lots of fun.
    As paddi70 says there are lots of instructions available including those on the other clients download page linked in his post.
    If you have specific issues help is at hand here. :thumb:
  5. murraynt
    murraynt Modder
    6 Jun 2009
    Thanks for all the help guys the cpu is up and running. I will start the GPU one aswell.
  6. cdb
    cdb No comment
    25 Apr 2009
    Will a 2500K complete a bigadv in time? It's only 4 threads isn't it?
  7. paddi70
    23 May 2009
    Your right, my bad, sorry Murrynt, I didn't realize they were 4 core, even with your OC it would struggle to make the correct TPF and in turn miss deadline.
    Be worth seeing what it produces mind.
    Cheers cdb
  8. MrGumby
    MrGumby CPC 464 User
    27 Apr 2009
  9. StreetSam
    StreetSam Minimodder
    30 Aug 2005
    Now I know nothing about Sandybridge CPUs, but doesn't a 2500k have four cores, so no BigAdv. But a 2600k has four cores with HT so it will do BigAdv.
  10. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
    Welcome to the team :)
  11. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    what is the passkey is it the team number ???
  12. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    Yay, new folder!
  13. Christopher N. Lew
    23 Apr 2009
    No, the passkey is uniquely linked to your account. You have to request it from Stanford. See this page.
  14. murraynt
    murraynt Modder
    6 Jun 2009
    Ah yes that explains it. I'm going to run the standard SMP client now.
    One or two more questions.
    I have my SMP client in my documents and my GPU one in downloads. Should i move both to the same folder?
    I'm using a passkey for my SMP client should i be using one for my GPU aswell?
    I am saving the finished data every 4min, is this ok?
    And finally if i wanted to run my GPU and 95% just to give it some headroom do i have to create a shortcut for the GPU client and add -configure or can i just add in on after the .exe program.
    Thanks guys.
    Last edit: My CPU is at 4.3ghz and the 275GTx at stock (Hopefully i will bring this 2500k up above the 4.6ghz mark) It's getting a PPD of a tad over 20000,is this respectable?
  15. MrGumby
    27 Apr 2009
    Only other thing you might wanna do is put your folding stats in your sig. Check out the sticky in the folding forum. I reckon a 2500k @ 4.3 would do about 20k a day and the 275 around 7 or 8k? Dont know what hit folding on the gfx card will have on your cpu ppd tho.
  16. murraynt
    murraynt Modder
    6 Jun 2009
    According to F@H.NET my 2500K is only getting around the region of 10-11k now. :sigh:
  17. MrGumby
    27 Apr 2009
    Try folding on just the cpu first. I use HFM to monitor my ppd. Also have you returned 10 WUs yet? You then start getting the bonus points.
