Yea, well, after buying countless number of heatshrink tubing and meshing sleeving, and all sorts of wire connectors. I had a gigantic task on my hands. I had to shrink about 30 different wires. Well, here's what I had in mind to use in the first place: Soldering Iron. Well that sucked, that would have taken forever. Well, I decided to place the iron on the kitchen counter so I wouldn't light the house on fire. Then I saw my old Toastermaster and removed the tray. I turned up the the temp to about 450F and stuck all the individual wire pieces on the tray and stuck it in there. Non-shrunk to shrunk in 2 minutes (including heat up time). 30 pieces done just like that. Whoohoo! Yea, I only used like three tools on this case: dremel, screwdriver, and toasteroven. Sweet.
