Peripherals niggling problem
Discussion in 'Tech Support' started by ajangusjames, 27 Dec 2011.
  1. ajangusjames
    ajangusjames What's a Dremel?
    26 Dec 2011
    I have recently built my first pc :D but sadly no sound plays, :wallbash:but don't think i am an idiot because i have check the volume, the device, the jack, the drivers, and i have replaced the sound card, soon i will be updating my CPU but, the only thing that i have not done is reinstall windows 7 which i will try soon (as i am not at home) but if you have any other ideas, they would be very useful!!!:clap:
  2. Tribble
    Tribble Steals Avatars
    14 Oct 2011
    I would check all sound settings in windows, I know my asus d2x can be a bit iffy with drivers, so my other call would be uninstall drivers, reseat card and then reinstall.
  3. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    Will sound come out if you remove the card and plug into the motherboard's sound jack?
  4. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    Have a look in Device Manager and see if there are any warning signs next to your audio device and see if you can fix it from there.
  5. ajangusjames
    26 Dec 2011
    OK, CHEERS FOR THE ADVICE
    yea, ok i will have ago and let you know if it works.:thumb:
