Case Mod - Complete Nintendo Switch mod - Shiny Charizard
Discussion in 'Project Logs' started by Dietec, 3 Nov 2018.
  1. Dietec
    Dietec Minimodder
    2 Oct 2017
    A human asked me to modify a nintendo switch to be themed around the shiny version of the pokemon Charizard!
    For the uninitiated, "shiny" refers to the alternative color that a pokemon can be, and it's very rare to find a pokemon with the alternative color in the games so they're highly coveted. Charizard is a dragon looking creature, he's usually orange but his shiny version is black. Like this:
    Now obviously the actual handheld part of the nintendo switch needs to stay pretty much the same because if you change its shape, it becomes a lot less portable and usable, which I would like to maintain. The dock however can be changed a ton because it's just supposed to sit in one place forever anyway. So, I've decided to take the switch dock and make it into a shiny Charizard. I might also paint the handheld part, that could be cool and it wouldn't change the functionality.
    First I took apart the switch dock and removed the PCB inside that connects the switch to the ports. The PCB connects to the switch by a ribbon cable with a USB-C attached to it. All you do is plug the power cable and an HDMI cable into the PCB and then plug the ribbon cable into the switch, super simple.
    I cut up the dock to get the PCB enclosure part only, this will protect the delicate parts while I sculpt my Charizard around them.
    Going to use this apoxie clay to sculpt the mod :)
    _Prometheus_ and kim like this.
  2. kim
    kim hardware addict
    10 Jan 2016
    I love this sort of modding...I mean, modding something different than just a PC, I'm following :thumb:
    Dietec likes this.
  3. _Prometheus_
    _Prometheus_ Minimodder
    2 Jul 2017
    Oh, what intrigue. :) I'm following too. :thumb:
    Dietec likes this.
  4. Yaka
    Yaka Multimodder
    26 Jun 2005
    ohh this seems cools
    Dietec likes this.
  5. Cheapskate
    13 May 2007
    Hacking 60% of the case away and pulling out the mud. :thumb: Gonna be a proper mod.
    You gotta set it up so the chari-whatever is hugging the remote when docked.
    Dietec likes this.
  6. Yaka
    Yaka Multimodder
    26 Jun 2005
    how does apoxie compare to milliput or sugru? ive heard part b has stinky smell to it is it as bad as some say?
  7. Dietec
    Dietec Minimodder
    2 Oct 2017
    I don't notice any kind of strong smells. Doesn't bother me any, and I've not used those other types so I can't say!
    Yaka likes this.
  8. Mopsi
    Mopsi What's a Dremel?
    12 May 2017
    as soon as the apoxie scult is cured, there should be no smell at all.
    I would go with the apoxie sculpt over miliput. I personally use miliput only to fill in small gaps in my prints.
    If you want to save some money, you can also try "magic sculpt" basically the same as apoxie sculpt
    Yaka and Dietec like this.
  9. Dietec
    Dietec Minimodder
    2 Oct 2017
    Getting close to finishing the sculpt now! This took a while what with the holidays and stoof.
    Just need to sand down some of the rougher parts and paint him :grin:
    This is how the internals are sitting inside of his body. All held together by the apoxie sculpt.
    Looks kind of tasty so far... This is actually the point where I handed the sculpting reigns over to my wife, because she's way better at sculpting than I am. And she did a great job!
    He stands on a tripod, two legs and his tail. There's really no way he's falling over ever.
    The arms were a bit harder to sculpt because the clay doesn't like to stay in place, so we had to do things bit by bit letting the bigger parts harden before we attached them together. Turned out ok though, just took a little bit.
    I cut some wings out of acrylic and used my new home made acrylic bender to bend them into shape! They turned out great, there was no way we could have made wings with clay alone
    After attaching the wings and arms, we tested the fella out and by golly he works!!
    Had to make a little cradle for the switch to sit in on his back though, otherwise it would be too insecure and might get knocked off or something. Just added a little circle to hold the switch in place.
    Don't judge us, we still have to smooth out some areas :p:
    Almost ready to paint him!!
    Yaka likes this.
  10. Dietec
    Dietec Minimodder
    2 Oct 2017
    The switch mod wouldn't be finished without changing the look of the handheld portion, but we can't change its shape without sacrificing functionality so we just made it look cooler.
    I took the back part off the console and primed it, sent it over to my friend Hassan at v1tech so he could use his suuuper expensive printy-thingy to print a picture onto the back of it. Check him out if you'd like, he's a very nice person (www.v1tech.com)
    Still need to clear coat it, and that will make it glossy!
    Before fancy printer:
    After fancy printer:
    I like.
    Yaka likes this.
  11. Cheapskate
    13 May 2007
    :lol: He looks like he needs to run around the block a few times. I guess that'll happen when you eat a big square box of electronics.
    Dietec likes this.
  12. Yaka
    Yaka Multimodder
    26 Jun 2005
    i think that is a damn good mod, well done mate
    Dietec likes this.
  13. Dietec
    Dietec Minimodder
    2 Oct 2017
    After painting him, he's done! Special thanks to the wife, who is basically the star of this show. Made a video mod log too, check that out if you want. HE'S DONE!!
    Dr. Coin likes this.
  14. TheMadDutchDude
    23 Aug 2013
    This just gave me an awesome idea for me to try on my 3D printer...
    I'll post a log if it goes well. :D
    Thank you, dude! :)
    Dietec likes this.
  15. Dietec
    Dietec Minimodder
    2 Oct 2017
    3D printer would probably be faster honestly lol. Clay takes a long time
  16. kim
    kim hardware addict
    10 Jan 2016
    Very cute result :thumb:, 3D printer would probably make it faster, but it would lost the personal touch of the sculptor, and most of the interest I had watching the video...
    Dietec likes this.
  17. TheMadDutchDude
    23 Aug 2013
    Concept created ... just got to wait 12 hours for a rough print of the center piece. Then to reprint in finer quality as well as the remainders if it goes well...
