Windows NO BIOs HOLP!!!!!!
Discussion in 'Tech Support' started by disturbed13, 29 Jun 2009.
  1. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    when i try to start the power on my pc
    nothing happens
    the fans power up
    my monitors are on
    but no BIOs boot
    no OS
    nothing
    ive gone to work with it on, and when i return its off
    and my keyboard is still illuminated
    but there isnt any fans that are running in my case
    what i did to get to this mess up point
    my primary HDD only shows ~600GB when it is a 1.5TB HDD
    so i cloned my primary to another
    and that worked
    i just havent found the time to re-format my primary HDD
    and then re-clone all of my info
    so i think it the fact that there are 2 OSs and what not that is causing a conflict and it shuts down
    does anyone know what i can do to be 100% sure
    im at work now so it will have to wait
    i was thinking about unplugging the SATA power and hoping like h3ll that it works
    any thoughts?
  2. disturbed13
    28 Nov 2008
    i disconnected the power cable to the cloned HDD
    and its still doing the same thing!
    the CD rom is also unresponsive
    can anyone give me any options here?
    im at a complete loss
  3. Jozo
    Jozo This is bit-tech
    14 Mar 2009
    • First: check out your power cables on the motherboard (both ones, the ATX 20/24 pin and the 12V 4/8 pin) and the graphics card
      (My PC once would turn on then off after 5 secs and it turned out my power cable moved a little)
    • Second: Disconnet any hardware you currently don't need, extra HDDs with other OSes etc, and if possible change the questionable HDD and try putting a fresh OS on a formated drive
    • Third: try flashing your BIOS
  4. Nicb
    Nicb Let's discuss among ourselves
    12 Nov 2008
    Even thou your keyboard lights up and case fans spin, I say you have a dieing Power supply.
    If you can get another Power Supply to test from another PC, stock pile, or friend. That would be the easiest way to approach this.
    No "average Joe" way to Flash Bios Jozo, he can't even boot.
  5. Akava
    Akava Lurking...
    28 Jul 2007
    I think the above posts are right, failing power supply, how ever you may find that changing your CMOS battery fixes it, at least temporarily.
