overflow:auto; I don't know if anyone else finds that little tiny bit of code exciting... I do though Well, maybe not exciting, but definitely nice. Basically, since the dawn of time (last may) I've been using <br class="clear" />. A dirty little bit of code that stops containing div's from not surrounding their contents if they are floated. Now though! overflow:auto; Its not a discovery of mine by any means, but I read it somewhere, and I had never heard about it before that day and I know there are people on here that do the web design/development dance and I thought it might be helpful.
I didn't know that worked either! Nice find. I do my best not to use the clear property by floating things within floated elements.
'visible' is the default overflow setting. Interesting, the spec for 'auto' says that it's user-agent dependent. How many browsers have you tried it in Will?
works in everything I have on my machine. ie7 ie6 ie5.5 opera (whatever the latest one is) firefox works in safari as well according to the office mac-humper. Bearing in mind, I've been testing it with very very basic css. just 2 floated div's and a container and a footer clearing all of that. I see no reason why anything might happen that isn't already known about though. Its already making my life easier.
The only thing that worries me is that if you want to specify a width or height on the containing you might end up getting scroll bars if the content gets bigger.
hmmm... you are correct... If the containing div (the one with overflow:auto; ) does get scroll bars if the content gets too big. See the code below. Thing is though... if your floating something within a fixed height container.. not only should you not need the fix, your layouts going to go a bit nuts if the content gets bigger anyway. Code: <div style="background:#ff004c; height:200px; width:450px; padding:20px; overflow:auto;"> <div style="width:10em; height:10em; background:#CCC; float:left; color:#FFF; margin-right:20px;"> </div> <div style="width:10em; height:10em; background:#333; float:left; color:#CCC;"> </div> </div>
Surely, having scroll bars is better than making the content unreadable... That seems to actually require a height as well...
