No Name - Project Acrylic Cheap
Discussion in 'Project Logs' started by Jack, 19 Feb 2005.
  1. Jack
    Jack Minimodder
    22 Dec 2002
    Hi guys
    Well im off on another log, hopefully ill be able to finish this one as older projects just seemed to fade away from me...
    So what's my plan? well TBH im kinda doing this on the fly thinking of idea's as i go along, obviously i have certain plans to keep to but things may change :p
    Let start by saying whats going into the project.
    A64 3500+
    K8N SLI Platinum
    X800XL
    1Gb Ram
    couple of HDD
    A DVDRW
    And something else ;)
    Now for the case! as the title surgest's this is arcylic on the cheap :) and were better to get that from in uk than ebuyer :p the case was brought for a grand total of £35 :) here it is http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=52795
    I will have to say that on arrival i wasn't to impressed regarding the case certain bits just didnt fit right one of the sides were curved and didnt really fit properly but for the price what would you expect? Luckily for this project this all didnt matter to much.
    So here's the case with all the bits inside
    What i needed to do now was test design's out so i went down my local Hobby Craft and brought a large sheet of black card type stuff costing a total of £1.50, i then marked out a design on the card (I try'd many different design's but perhaps its just me i like the basic windows better!?).
    I then cut out the marked area's and placed the acrylic side panel on top to check fitting.
    Next step was to install the side back on the case with the black card behind just to see how it all looked
    I was impressed with the results obviously the end design wont be a black piece of card behind the acrylic, but for test purposes it really helped give a feeling on how the side would look.
    Next up was to place some car window tint behind the black card this was brought from halfords along time ago so i dont know the price of it but i have to buy more so will let you know later
    And... thats it for now :) next update will be the final side panel all finished
    If anyone has any ideas regarding the design of the panel then let me know who knows i might like your idea :)
    jack.
  2. Dean_j2001
    Dean_j2001 What's a Dremel?
    1 Apr 2003
    cool man aint seen a clear plexi mod in a while everyones going off with lian li's now etc good luck looks good :D
  3. Rufus-Seal
    Rufus-Seal Guest
    :jawdrop: :rock: W00T it looks really really really cool! :naughty:
  4. Silenced`
    Silenced` What's a Dremel?
    28 Aug 2004
    nice effect man, why don't try it at every side of the case ? You can cut a draw out in the paper of the left pannel than ? just an idee :)
    grtz,
    Thomaz
  5. Cyberbob:-)
    Cyberbob:-) Minimodder
    16 Jun 2002
    I like it, thats a nice idea using the card. makes it stand out... :thumb:
    And another modder who is from the midlands.. :D
  6. Jack
    Jack Minimodder
    22 Dec 2002
    :clap:
  7. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Really good looking, exspecially with the paper thingy.
  8. Jack
    Jack Minimodder
    22 Dec 2002
    Not really an update as such but a little teaser :)
  9. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    :thumb:
    Really really nice. It's good to know that there is a substitute for not having a CNC Mill......Paper! Outstanding
    Nice job
  10. Rh1n0x
    Rh1n0x What's a Dremel?
    15 Nov 2004
    It looks like an early Sunbeam fabricate...
    Maybe use more steadier material instead the paper for those cover ups.
    Though I don't fully understand the progress of buying an acrylic case and then to try to take away the effect of full visability?
    Nice concept though!
    Mod on :thumb:
  11. Jack
    Jack Minimodder
    22 Dec 2002
    Perhaps reading may help you understand that
    http://www.bit-tech.net/article/63/ i wonder
  12. Jipa
    5 Feb 2004
    Only problem is why didn't I do that before u :D That looks SWEET! I dont like normal plexi-cases like that WAS, but u'r really making it look awesome!
    Keep moddin'! :clap:
  13. Dean_j2001
    1 Apr 2003
    nice one Jack i liked that reply :hehe: i 2 was also thinking about macro black when i seen your case. it is looking brilliant!
    what sorta colour theme you going with?
    just your case is black with tinted blue plexi but the psu is sleeved red and black?
    you going to put some watercooling in it? i know the title says cheap but judging by the hardware i'd say the only thing cheap so far has been the case.
    anyway good luck
  14. Jack
    Jack Minimodder
    22 Dec 2002
    No water on this case, im looking for it to be as cheap as pos!
    As for the hardware no-one should skrimp on that IMO
    color black blue red
  15. Rh1n0x
    15 Nov 2004
    ah, that's quite enlighting :cooldude:
    mod on. why go cheap? The Hardware you got in there ain't cheap at all :grr:
    If you've got any money probs..
    Spermbank! :thumb:
  16. mattthegamer463
    26 Nov 2004
    they pay for that!?! i have to leave now...
  17. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    :hehe: Yes they do!
    <A88>
  18. frodo
    frodo What's a Dremel?
    1 Nov 2003
    The more acrylic case mods i see.. the more tempting it is to go get my Beantech BT-8 down from the loft.... i always wanted to make fake windows... i still might go nab it from the loft... only problem i had was that the back panel didnt like heavy PSU's, so my back panel was slowly bending from the weight of an old 500w psu
    i might use the acrylic case for my latest mod.... downside would be that im planning on watercooling it like mad, so it would have 2x BIP's (well just look in my sig for future rig)
    all in all that would be very heavy.. so id have to find a way to re-inforce it all
    good looking plans... acrylic case mods are always nice imo
  19. speedybe
    speedybe What's a Dremel?
    18 Apr 2004
    maybe you should look better, I've been working on a plexi mod for 2 months now, project NW-01.
    great work with the paper, so simple and yet beautifull :rock:
  20. Dean_j2001
    1 Apr 2003
    There's no need to get pedantic about it, i didn't literally mean there is absoultely NO other case mod's being done at the moment which are plexi. Only that it's been a while since i seen a new one
