noblesse revisited
Discussion in 'Project Logs' started by ISM, 27 Apr 2003.
  1. ISM
    ISM What's a Dremel?
    6 Mar 2003
    its my first time posting pics so if they dun work i'll jus put the websites.
    The only thing the pics show at the moment is the new piece that takes the place of the power and reset buttons. Both cd roms will be stealthed (plexi already cut just need to get the paint) and the floppy will be moved. I have also been working on creating a new upper bezel but that is also waiting for the paint.
    *edit* pix removed
  2. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    Sounds good, but ya need a little better camera.
  3. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    understatement of the year award goes to....................... ZAP!
    but nayhoo.. doth sound good push on with it... and scrounge a decent snapper
  4. ISM
    6 Mar 2003
  5. ISM
    6 Mar 2003
    pics of the bezel 1 2
    and one of the entire case
    the top of the bezel where the black horizontal pice of plexi is will be the word noblesse much like macro did in macro black.
    the cd drives will be mounted 90 degrees from where they are now. then the rest of the bezel will be built around them.
