News Noctua unveils first Sterrox LCP fan
Discussion in 'Article Discussion' started by bit-tech, 4 May 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    They still haven't found the secret to mass producing black plastic though.
    Impatience and MLyons like this.
  3. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Yikes
  4. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    £30 a fan is par for the course with Noctus. But £10 for a plastic adapter plate? Fuuuuck that.
    blackerthanblack likes this.
  5. blackerthanblack
    blackerthanblack Minimodder
    17 Sep 2004
    Yep, want quality? then we have to pay for it - for a fan that for many will last several builds.
    But if they're saying that a plastic adaptor has over a third of the R&D, engineering, material cost and packaging as the fans, then no, just no.
    MLyons likes this.
  6. edzieba
    14 Jan 2009
    To be fair, tucked in the description for the NA-SFMA1 is that it includes two bits of single-shot-moulded plastic. So it's only £5 for a single lump of plastic.
  7. Mr_Mistoffelees
    26 Aug 2014
    I can't say I have ever had a problem with the coefficient of expansion of my cooling fans being too high...
    adidan and MLyons like this.
  8. Anfield
    Anfield Multimodder
    15 Jan 2010
    There are the issues of over-engineering for the sake of it and diminishing returns to consider though, because the existing Noctua fans are already extremely good.
  9. adidan
    25 Mar 2009
    You've not lived.
    MLyons and Mr_Mistoffelees like this.
  10. karbonKid
    karbonKid Minimodder
    5 Jul 2006
    Did you read the article? The low CoE was sought so they could reduce clearance between blade and frame, not as an end in itself.
  11. Mr_Mistoffelees
    26 Aug 2014
    Had I not read the article I wouldn't have known about the low CoE plastic but, hey-ho.
    BTW, my Fractal Design Silent Series R3 140mm fans do a fine job with minimal noise and cost me around £9 each, early last year. Inefficiency, due to excessive clearance betwixt fan and frame, doesn't seem to be a problem. Don't get sucked-in by too much marketing speak.
  12. MLyons
    3 Mar 2017
    But the real question and decider of price and quality is do they have RGB
  13. RedFlames
    23 Apr 2009
    Don't forget Noctua punt their wares for industrial applications too... so while they won't grumble if some PC types buy these over engineered, overkill fans we're probably not the target audience...
  14. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    If reducing the clearance between the blade and frame is such a big deal, why not integrate the outer ring into the blades and have it spin?
    I'm sure there is some kind of aerodynamic effect that would makeit pointless, plus balancing the outer ring would probably mean some kind of post mould machine cutting too, but it would look dope AF, so I want it.
    I will pay extra for fans that don't.
  15. RedFlames
    23 Apr 2009
    Isn't that the thought process behind these?
  16. fix-the-spade
    4 Jul 2011
    Never seen those before, definitely want.
  17. RedFlames
    23 Apr 2009
    They're Noiseblocker NB-eLoop fans and can be had from here. They are, iirc, well regarded.
Tags: Add Tags
