Windows Nocturnal Computing Problem
Discussion in 'Software' started by Jordan Wise, 29 May 2009.
  1. Jordan Wise
    Jordan Wise Baby called to see the boss...
    24 Jul 2007
    Problem :
    Want to use my computer at night, in the dark, but not get dazzled by the screen. Black text on a white background irritates me beyond belief in the early hours as I'm always squinting when looking from a dark background on one screen to a bright one on the next (I have 2). I don't know why all programs don't have dark backgrounds with white text, like Spotify and Steam do. I realise that there's no changing websites, but if just the general background colour for windows and text I think it'll carry on through other programs, such as Eclipse and Notepad++ (which i use a lot more than most things) could be changed they please, tell me how and I'll be eternally in your debt.
    From my own research I found that there is a program called Nocturne that can do this, but only on Macs:wallbash:, I couldn't find a PC version.
    Is there any way it can be done using Windows alone (Vista Ultimate 64 bit)
  2. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    easier method, buy a lamp 5w or something just to light the area a little.
  3. gnutonian
    gnutonian What's a Dremel?
    6 Jan 2009
    Can't you make a second theme with dark backgrounds? I'm thinking about Windows XP here, but in the appearance settings (when you right-click the desktop and click "Properties") I remember the first tab being themes you could pick/save, and in another tab you could change the colours to a pretty "advanced" level (for MS Windows anyway). I remember it including background colours of applications as well.
    I'm not sure how helpful this is as my memory is a bit hazy and I have no idea about Vista, but it may be worth to have a look? If it works, it's a few minutes to get it the way you like and hours of no squinting :)
  4. Jordan Wise
    24 Jul 2007
    No room on the desk and no free sockets for lamps. Besides, I want darkness.
    I've tried looking in the themes and background colour business in control panel, got nothing so far. I'm wondering if theres a way of doing this from deeper within windows, like something into command line that will change it throughout windows, as I think the Mac had a solution like that, based on the CLI
    Cheers for the fast responses though
  5. Digitalize-
    Digitalize- What's a Dremel?
    23 Apr 2009
    Just turn on a High Contrast Theme, there is one thats black white and purple i think.
  6. Jordan Wise
    24 Jul 2007
    I've tried that, quite good but doesn't turn all characters, only letters. I need the characters changing too or it's impossible to write code.
    Does anyone know if Windows 7 has a solution?
  7. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Try this.
    Right click desktop > Personalize > Window Colour and Appearance > Open Classic appearance properties > Advanced.
    Thats the thing Impreium is on about I think. I'm pretty sure it carries through most apps if you change the right things, but IIRC it doesn't effect interweb.
    thehippoz likes this.
  8. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
  9. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    For web related colour changing-ness, Firefox and Styler will work. Just have it set your body to black and font to white, or vice versa!
