Build Advice Noob: Comp build help
Discussion in 'Hardware' started by MarkW7, 3 Dec 2008.
  1. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    No, you should have it blowing onto the GPU. :)
  2. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Ermmm? Blowing or sucking?
    Also would a CPU heatsink and fan do the job?
  3. azrael-
    azrael- I'm special...
    18 May 2008
    According to Bart Simpson things can both suck and blow at the same time... :D
  4. azrael-
    18 May 2008
    No, because you wouldn't be able to fit it on the graphics card.
  5. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    i need a special adapter just for this card, specail fan don't know wether suck or blow.
  6. azrael-
    18 May 2008
    Have you considered posting in the Marketplace forum? I bet someone in the UK could get you an old standard R9600 cooler, as people often replace the standard cooler with something better.
  7. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    vBulletin Message
    MarkW7, you do not have permission to access this page. This could be due to one of several reasons:
    1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
    2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
    3. Your account may have been marked as inactive. Please contact us if you would like your account reactivated.
    Log Out Home
  8. azrael-
    18 May 2008
    I posted a message in the UK marketplace forum on your behalf. Perhaps something will turn up. :)
    Hope, I didn't break any forum laws...
  9. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    Best bet... go around to your local computer shop and ask if they have any old* PCs lying around that need geting rid off, I'm sure they'll have a heatsink and/or fan you can steal :)
    *Pentium 3/Socket 478, might have an old GFX card in there as well that you can add to the stockpile
  10. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Thanks.
  11. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Anything come up yet?
    Recieved my LAN and usb 2.0 card yesterday :d
    And i need the fan on the graphic card draggin hot air out.
  12. bigsharn
    9 May 2008
    I meant for you to go around and ask in the shops :p
    I live in Yorkshire, if you can find anyone to give you something for free here, it's a scam or an advertisement
  13. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    I've been to one but it's a grumpy old guy lol
    I have a 80mm case fan that i've had for a bit i know i cant use it on the GPU but i cant see any arrows on it and i don't understand how i can pull hot air, it only seems to blow cold to me. ??
  14. bigsharn
    9 May 2008
    Reverse mount it, then it'll pull hot
    Make it so that the air is going away from the card :) (and just use bulldog clips for now, they'll do til you get a proper cooler/GFX card)
  15. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Oh, so i just put it on so its blowing cold air away from the card, therefor when it heats up it will blow the hot away.
    That really works lol?
  16. mm vr
    18 Nov 2007
    Simple physics, a fan does BOTH draw and blow air. At the same time. Doesn't matter what temperature it is.
    But I'd still suggest putting it the way that it blows ONTO the GPU... Every stock cooler I've seen is like that.
  17. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    I'll just face it what ever way it comes :) , do you know any good sites i can buy a fan / heatsink.
  18. MR BUNGLE
    MR BUNGLE Shoddymodder
    19 May 2003
    Hiya dude!
    - I definately have a 9800 pro cooler lying around at home, and I'm pretty sure that'll fit your 9600 pro. (If not, an old P3 heatsink should do the trick with a bit of :dremel:!)
    Will let you know when I get home boxing day.....
    Can cover postage - shouldnt be much, or could drop it over if you're anywhere near Littlehampton, West Sussex....?
    Merry Xmas!
  19. azrael-
    18 May 2008
    I'm sure you've made someone very happy now! :)
    Merry Christmas to you too!
  20. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    MR BUNGLE
    That'd be great and make my christmas :d
    Sorry, i don't live near west sussex is there anyway i can give you my address through private message or msn i don't really wont to post it here.
    Thanks, Mark :D
