Electronics Noob LED circuit help
Discussion in 'Modding' started by tommarndt, 13 Nov 2003.
  1. tommarndt
    tommarndt What's a Dremel?
    10 Nov 2003
    ok, im a noob at electronics, so i need some help with this.
    I have a crapload of LEDs that i want hooked up. All from the same molex connector. And each led will be turned on by a switch, and will fade out.
    I was going to hook them all up in parallel with a switch before each resistor and LED. Im not sure how to draw some of the symbols, so if you can't tell the V is the LED, /\/\/ is the resistor, and the S stands for switch. Would this design work?
    Code:
                   _
               ----V--/\/\/---S---
               |   _             |
               ----V--/\/\/---S---
               |   _             |
               ----V--/\/\/---S---
               |   _             |
               ----V--/\/\/---S---
               |   _             |
               ----V--/\/\/---S---
         Ground|                 |+5v
    And if it can work, where would I throw the capacitor s in to give them the fading out effect?
    BTW, how many LEDs would you be able to have on at the same time running off of one Molex connector?
    Thanks a lot guys.
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    For future reference, I use |>| for diodes, _/ _ for switches and v^v^v for resistors.
    Anyway, onto your question. I can't think of any simple way to get a simple fade out effect. A typical RC circuit will have a fade in and fade out effect. If you want to pursue that method, then 1 LED circuit should look like this
    Code:
                     R       C
    +5v - - _/ _- -v^v^v- - -||- - - - - - - GND
                         |- -v^v^v- - -|>|- - |
                             R-LED
    LED should begin to illuminate after about 1 time constant (R*C), while it will be at full-brightness after 5 time constants.
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I've a bench psu with a led "on" indicator that has a fairly slow fade out from the smoothing cap, so that would have
    Code:
          /S          R       LED
    12v--o  o--+---\/\/\/----->|----+
              === cap               |
    0v---------+--------------------+
    The fade may work better from a 12v supply than from 5v, try it with a 470uF 16v cap and 2k resistor and see how it goes.
    2k is not a typo. ;)
