Is it possible to have the notfred VM show the progress in its own window? Like you would with a standard Linux VM??? Its a pita to be at the machine with it on but have to use fahmon to check it. So much easier to just open the window to see.
log in to notfred as root use the command Code: tail /etc/folding/1/FAHlog.txt update: The "tail" command displays the last ten lines of a text file. You can use the "-f" option to tell tail to redisplay the file when it changes. Control-C to exit. I can't test this at the moment as my notfred is waiting for work. Note there is a space before and after "-f". The command is: Code: tail -f /etc/folding/1/FAHlog.txt
