got some led fans and a new uv/blue ccfl last week, got pics late cuz i was un holidays anyways, heres the pic (the uv ccfl sux big time, it works, but its not near as powerfull as any of the other ones i've seen ) what do you guys think?
lol i could get rid of those metal bitties on all 4 corners, and leave the circle around the fan like that
YEa that would look a million times better. Those metal pieces come from the center out look goofy to me for some reason.
HEY!!! YOUR CASE HAS BUBBLE TUBES LIKE MINE!!! THIEF!!! /caps off On the other hand it looks neat. Is the top bus beige though?!! Do your Bubble tubes change colour cause mine do
omfg that just made Iced tea shoot out my nose!!! edit: and it does look like vegas! i like the X shaped window
Like the X shaped window too. Gonna buy a similar case for my g/f. And it doesn't look girlie yodasarmpit
no the top bus is brushed aluminum like the rest of the case, only i havn't been able to fit a piece of plexi over it like everything else... as for the tubes changing colour, im wiring up a little thinger where they flash red during hdd activity
the only thing i see myself regretting is the powersupply rape i did last night...i took out like 3 strands of molex connectors, and the 2 p4 cables as it was -way- to much clutter in my case, even though they were hiding on the other side of the mobo tray, it meant taking that side panel off and having to take cover so that it doesnt spring back and smack you in the face. and the worst part is....it was still under warranty oh well, me likes the outcome
thx oh yea, there is a UV ccfl in there with 2 other blue ccfls, and believe it or not the hardware that i had painted still glows, and im picking up some uv dye later on tonight which i will add to my water and then the tubes will glow green hehehe
allright i added the UV stuff first off - it's called Flour-i-Strip and is availoable at any local Vetirinary clinic, i went there this afternoon and got 6 strips for free...i wouldnt mind another 4, each strip i put in kept enhancing the brightness...you submerse the strip in the water and then throw it away each strip contains 1mg of flourescein sodium (also found in anti-freeze) only theres like 1mg in a quart of antifreeze, lol PICS! so...?
